o3 SS consistency
Old Oct 29, 2004 | 02:05 PM
Default o3 SS consistency
Anyone know any tricks for how to make my SS more consistent at the track??? I don't care about going any faster or quicker, I just want consistency!
Stock 6.0, homemade MAS, throttle body spacer, volant ram air, flowmaster scavenger cat back system.
Thanks,
John
Old Oct 29, 2004 | 02:20 PM
F8L Z71's Avatar
Damn, you have all the mods that either ar not proven to work, possibly have flow problems and I'm not sure what a home made MAS is. LOL
Get rid of TQ managment and you should be consistant as hell as long as those questionable mods are not doing any harm.
Old Oct 29, 2004 | 03:25 PM
Last Call's Avatar
TOTM: January 2007
My buddy has an 03SS and that thing runs SUPER consistent. Between 15.25 and 15.35 all the time. He has a superchips programmer, duals flows, an x-pipe, and a volant CAI. Not fast, but conistent. All wheel drive make for some consistent 60' times. I think almost always in the 2.2 range.
Old Oct 29, 2004 | 03:33 PM
I dont have any kind of consistency problems at all either, and I never have. Are you allowing your truck to cool down between runs? make sure you let the truck cool down before every run, trans temp makes a big difference as well. make sure you have consistent tranny temps before you make your run. even with a stock converter you will see higher stall speeds with a warm trans.
Old Oct 29, 2004 | 06:32 PM
11 Second Club
Thanks,
John
URFULLOFSHIOTBIOTCH
Old Oct 29, 2004 | 06:43 PM
Breeze's Avatar
11 Second Truck Club
I dont have a SS but my 03 Silverado 5.3 is also very consistent with mods in sig between 15.30 & .40 are you spinning youre tires? let some air out.
Old Oct 30, 2004 | 03:48 AM
my 60 foots are consistent but i usually lose it on the top end. sometimes i can't cool enough before each round, guess that's the price you pay for going rounds. i have found lately that the density altitude has a major factor on my consistency. thanks for the advice.
Old Oct 30, 2004 | 03:52 AM
what is TQ management and how can i get rid of it? my homemade mass air flow sensor is simply the stock sensor with the honeycomb type screen removed. allows much more air into the large duct on the volant. i have found that a mix of either 100 octane race gas with 91 octane or actane booster in a full tank significantly improves my consistency usually. thanks for the tips.
Old Oct 30, 2004 | 06:25 AM
CHAGO's Avatar
my AWD 6.0 Denali was very consistent when I took it to the track:
15.0 @ 91mph 2.23 60'
15.0 @ 90mph 2.23 60'
15.1 @ 91mph 2.36 60'
15.1 @ 90 mph 2.28 60'
15.1 @ 91 mph 2.35 60'
Old Oct 30, 2004 | 06:32 AM
F8L Z71's Avatar
I'm concerned that you said higher pctane results in better consistancy.. If that's the case then your PCM is most likely pulling timing for some reason. It could be that your MAF sensor is leaning you out too much after you pulled the screen out. It happens on some trucks but not all.
Is there anyone in your area that has an scanning software that can data log for you?
Keep an eye out on the Volant threads also. There is rumor going around that some of the Volant models have flow issues. I guess there was a test done where the volant actually made a truck LOSE HP, instead of gain. There was a huge thread on the SilveradoSS.com forum.
Running the truck hot shouldn't effect the ET all that much unless you are having PCM issues. Even the tranny should make the times vary much unless you are hot lapping like a **** If you are then invest in a good trans cooler. It's money well spent.
