o2 sensors
Old Jun 9, 2002 | 02:33 AM
rphinney's Avatar
Default o2 sensors
I want to put cut-outs right up against my headers. Ie replace the cat, what do I do with the o2 sensor behind the cat? Isn't this one supposed to read what they o2 is like after the cat? so what are some suggestions. Also how will this affect my engine with the cutouts open and closed.thanx, oh yeah richard I checked out your site bitchin truck!
Old Jun 9, 2002 | 03:25 AM
oxidizr's Avatar
Moderator / Sponsor
Default Re: o2 sensors
You need 02 simmulators (electronically replace the signal sent by a normal config)...they allow you to remove the cat or use a cutout before the cat with out getting codes set by the PCM.
Richard
Old Jun 9, 2002 | 02:16 PM
rphinney's Avatar
where do you get them how much do they cost, and most important will this affect the PCM ability to make correct adjustments on the motor getting incorrect signals?thanx
Old Jun 9, 2002 | 05:04 PM
CashDudeHomie's Avatar
Just leave the front O2 sensors hooked up and put the O2 sims on the rear ones and you will be ok.
Old Jun 9, 2002 | 07:13 PM
rphinney's Avatar
where can i get them ?
Old Jun 9, 2002 | 07:21 PM
1999stepside's Avatar
Thunder Racing is one, here is a link, if it does not work, just go to www.thunderracing.com and then click the link for trucks, then the link for exhaust.
http://www.thunderracing.com/index.c...ategoryid=1031
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
