o2 Problem
Old Aug 26, 2005 | 07:28 PM
02BlueStepside's Avatar
Default o2 Problem
On my way home from work I keep hearing this sound like a chain is draggin. Well after I get home I lay down and look under the truck and see an o2 Sensor hanging down. So I pull it up on the ramps and let it cool before I go crawling under there.
Once it get under there, I see that the sensor is still in the bung on the exhaust but the wires and the heat shield(?) have pulled out of it. Is this something I should be concerned with right away? The front o2s do all the work correct? If this isn't something I have to deal with right know, should I tuck the wire and heat shield(?) away, or should I unplug it and remove it? Also, I would assume it is ok to leave the actual sensor still pluged into the exhaust. If I take it out it will sound like a leak correct?
Anyone know what could have caused this? Sorry for some of the ignorant questions, but this is new to me. Thanks
Old Aug 26, 2005 | 07:49 PM
03NHSilvy's Avatar
the rear O2 moniters cat efficiency, so you will likely get a CEL no matter what until you replace it, but for now, just leave the O2 in there till you get a new one, if you pull it now you will hear a sound like a exhaust leak, just tuck the wire out of harms way till you get a new one
Old Aug 26, 2005 | 08:01 PM
SSlow 4.8's Avatar
Same thing happened to me... i can hear it more when i go over a bumpy road.. sounds like the exhaust is about to fall off, lol
Old Aug 26, 2005 | 08:51 PM
Thats good news to hear. For now its just tucked out of the way. Anyone happen to have the part number for the rear o2s so I can check some prices. I know they are going to be more than I want to pay, but oh well.
Old Aug 26, 2005 | 09:29 PM
DrX's Avatar
DrX
Are you outside of the emissions warranty? If the sensor fell apart and it was not due to accident or abuse it could be covered under federal/state legislation.
Up here I believe it would be covered for at least 60,000 km(40,000 miles). Specified major components such as cats and PCMs must be covered for 8yr/130,000km.
Old Aug 26, 2005 | 10:25 PM
I am around 50,000. I will look into that though, thanks
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
