NOT your normal rocker tick
Old Mar 10, 2011 | 12:11 AM
  #21
RacinRust's Avatar
Atomic may be pretty darn close. I would do some basic mechanical checks first. Compression test, cylinder leak down check, tee in a mechanical oil pressure gauge & check oil pressure, check balancer bolt, check flex plate / torque converter bolts. 150K on the clock could be intermittently sucking air through the oil pump pick up tube seal. Check rocker arms and valve tip condition. All just a guess till suspected problems are confirmed or eliminated.
Old Mar 10, 2011 | 05:36 AM
  #22
FLA.SHEE's Avatar
already confirmed it's a lifter bleed down problem all else looks good! (thats why I changed them )
didn't know about the oil pump problems
Old Mar 10, 2011 | 09:27 PM
  #23
RacinRust's Avatar
Does the tick still come and go?
Old Mar 11, 2011 | 07:57 PM
  #24
FLA.SHEE's Avatar
All I've done so far was the lifters but...
yes , nothing changed, at 3000 + - for 30 sec. +- & they start bleeding down fast... go back to Idol & they slowly build back up
Old Mar 11, 2011 | 08:07 PM
  #25
zeake's Avatar
Oiling problem?
Old Mar 12, 2011 | 12:39 AM
  #26
Mang213's Avatar
lol now theres an idea
Old Mar 12, 2011 | 07:17 AM
  #27
zeake's Avatar
I posted that from my phone. I did not see all the other comments that were already on that topic.
I would be concerned that the engine is on its way out if the lifters had already been replaced.
Old Mar 13, 2011 | 12:15 AM
  #28
Mang213's Avatar
Im just messin with ya Zeake
Old Mar 13, 2011 | 07:53 AM
  #29
zeake's Avatar
I can take it. I just had to explain. Amazing I went there though. I am so unmechanically inclined. hahaha.
Old Mar 13, 2011 | 08:10 AM
  #30
chevymec's Avatar
I repalced the lifters that did the same thing but the guy had been driving it like that for a good while. I put the lifters in it at 165k miles. Same noise again. Repalced the motor and when I tore the old one down I found the cam bearings toast. The lower parts were ok, sides had bronze showing the the upper part looked like black tar and was real rough to the touch.
2nd truck I know has 250k+ on it( 6.0) and does it after a about 3 or 4k miles on an oil change. He replaced the lifters in it tracking down and intermittent misfire.Change the oil and it stops.
