NOT your normal rocker tick
Old Mar 8, 2011 | 03:10 PM
FLA.SHEE's Avatar
Default NOT your normal rocker tick
'06 2500, 6.0 ,150,000 ,stock -work truck
when it's on the interstate it starts to tick ( like a lifter bleeding down).
when you stop to check it out it acts like it pumps back up & quits ticking.
I assumed the only thing that would come & go would be a lifter problem.
16 lifters later, warming it up just after finnishing it & it starts again.
waited to make sure it just needed to bleed , it quits just like before.
If after warmed up hold it about 3000 for 30+- seconds it starts ticking,
shut it off (while it's still ticking) & by the time I start it up (after removing the VC) it quits to quickly ( or I get an oil bath LOL).
any ideas ???
Old Mar 8, 2011 | 06:03 PM
FLA.SHEE's Avatar
39 views & nobody has an opinion?
Old Mar 8, 2011 | 06:45 PM
zeake's Avatar
Is your cam shot?
Old Mar 8, 2011 | 08:30 PM
FLA.SHEE's Avatar
how would a bad lobe make it erratic though?
Old Mar 8, 2011 | 08:34 PM
zeake's Avatar
I don't know. I am no tech so just throwing my guess out for ya.
i recently had some bad push rods. PRW sucks. It wore the end of the push rod down at the rocker. On a bunch of them.
Old Mar 8, 2011 | 09:46 PM
FLA.SHEE's Avatar
your the 2nd one to say cam, I just don't know how a cam would be erratic?
Old Mar 8, 2011 | 09:52 PM
Atomic's Avatar
I have a gauge for that
I say oil pump...
Old Mar 9, 2011 | 04:32 AM
FLA.SHEE's Avatar
Originally Posted by Atomic
I say oil pump...
why only one rocker. we sample our oil & haven't seen any signes of any changes in metal...
Old Mar 9, 2011 | 09:39 AM
Mang213's Avatar
What about the rocker on that cylinder? 150k on the clock, Im sure those needle bearings are ready to spit on you. Did you torque the arm properly? Maybe a preload problem?
Old Mar 9, 2011 | 11:22 AM
FLA.SHEE's Avatar
yep torqued... & it comes in at constant 3000 ish & then goes away after rpm's are backed down for a time???
It acts like the lifter is bleeding down & pumps back up ???
