Not happy with 6.0 performance
Old Dec 26, 2011 | 12:49 AM
  #41
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by AKlowriderZ71
Get some 4.56 gears in that thing, and I think you'll be alot happier. The rest of the setup seems pretty solid.
This is the same way I am thinking.. For the things you have done you picked up a decent amount of HP, basically (same heads, just raised comp) a cam and tune. The tb is neither here or there.. The bigger verter is not that great of a idea in a towing situation.. The bigger(lower) gears will help more then a converter, not hurt the trans.. If your looking for big block or diesel tq, your prob not going to find it in a 6.0, moreso in your 408 or a boosted app..
Old Dec 26, 2011 | 04:31 PM
  #42
kody1k's Avatar
I would think it would make more mine made 403hp and 382 with my 4l80e and a 10 bolt but mine has l92 heads
Old Dec 28, 2011 | 12:05 PM
  #43
mike058's Avatar
Highway hauler
Have any of you guys considered an add on overdrive? there is a quality one out there that lets you install it as an over OR an underdrive. 3.73s with a twenty per cent underdrive gives you 4.62 final drive, and with the low gear of a 4l60e that is some serious torque multiplication!
That is my plan when I rebuild my 5.3/4l60e combo in my 2000 1500 with 3.73 gears. You dont have the pain of setting up the rear end either.
Old Dec 28, 2011 | 01:40 PM
  #44
Bama2door's Avatar
^ I've never heard of this...is that really true? You aren't changing any of the hearing in the truck so how can you get a 4.62 ratio after that?
Old Dec 29, 2011 | 09:36 AM
  #45
baSICK5.0's Avatar
More gear and bigger convertor you'll be happy. but you gotta rememeber also...that truck with big tires...is HEAVY
Oobray
Jun 13, 2022 03:38 AM
greedygenius
Sep 3, 2015 06:51 AM
smokeshow
Aug 23, 2015 08:23 PM
captrob62
Aug 3, 2015 08:44 PM
cbhedrick
Jul 20, 2015 10:12 PM
