Not happy with 6.0 performance
I have a 6.0 in my 2000 2500. It has 65,000 on the engine. I have added LPP long tubes with ORY and 3 inch magnaflow exhaust, 8.1 marine injectors, 243 heads, ported and polished tb, and an EPS cam. The cam specs are 218/226 at .050 .598 lift on a 114 lsa with 4 degrees advance ground in.
At the dyno tune, it only put down 305 hp at the wheels. I was hoping for 330 or so. My tuner attributed it to the reciprocating mass of the 4L80 transmission, 14 bolt rear axle, and the 12 ply mud tires. Does this sound reasonable? The truck is definately faster, but still feels soft in the lower rpms. Oh yeah, I am also running a yank 2400 stall converter.
True, running a 4L80E will yield lower results vs a 4L60E, but with you being a heavy truck you gotta have that heavier duty transmission. Each dyno yeilds different results as well to the next one.
Take it to the track first and get some times, its not all about the dyno #'s.
Also about it feeling kinda soft still on the low end, maybe you should of went with a 2800 converter at least, but I am sure it runs fine with the 2400 you have now.
Dyno's don't honestly mean $hit without a stock reference point so don't even look at that. A looser convertor and no doubt some gearing would probably help with your soggy bottom end.
The truck has 3.73's. I built it as a towing rig, hence the mild converter and cam. My tuner overlayed my results over a stock 2001 6.0 and the difference is about 80 rwhp, and much improved torque throughout the run. Right now im running 285/70r 16 mud terrain tires. A switch to 4.10 gears is coming asap. Im not unhappy with the way it pulls my trailer's, but expected a little more. I do wish I had went with a higher stall, but the guys at Yank suggested this converter for my purposes. For what I did to it, my tuner was fairly impressed, and he knows his ****. I think a 408 build is in my future. Ill try and post my dyno sheet tomorrow.
I see. Yank basically sold you a stock replacement torque convertor so unless yours was bad initially you could have saved some cash there. 4.10's will help a bit with your 32" tall tires on the truck but it's still not going to pull really hard down low. 4.30's would probably be about just right but by the looks of things you have the choice of 4.10 or 4.56. Good luck with the truck.
