Noise from engine
Old May 15, 2005 | 09:19 AM
Default Noise from engine
When I am driving about 60mph, and I barely hit the gas my truck makes a hissing noise. It kinda sounds like wind, but when i let off the gas it goes away. Is this an exhaust leak? I put headers on a few months ago and noticed one bolt was broke. I left it because it wasn't leaking. I also used the paper gaskets with the kit. It doesn't make this sound at idle. Does it sound like an exhaust leak? Should a new set of stock gaskets fix this? Thanks
Old May 15, 2005 | 10:50 AM
litreddevil's Avatar
Banned
Well Which Bolt Did You Brake And Yes,it Would Be A Good Idea To Put The Stock Gasket Back On To Start.with The Bolt Broken It May Have Warped The Flange.
Old May 15, 2005 | 11:11 AM
SSlow 4.8's Avatar
Idk, bc he says it doesnt make the sound at idle or maybe thats because there isnt enough exhaust flowing through to make the sound. What about that vacumm line on the top of the engine, towards the rear, you can get to it w/o having to remove anything, is that still attached and working?
Old May 15, 2005 | 09:06 PM
The bolt is on the driver's side against the firewall. The noise is more noticeable when the engine is at its normal running temperature. If you start it up and take off it sounds good. I'm guessing the metal is getting hot and stretching to make a little leak. It's been doing it for a while, about since i put the headers on. Will it hurt anything to keep driving it like this?
I'll look at the line tomorrow.
BTW where can you get some stage 8 header bolts? When I replace the gaskets i think i am going to put some better bolts in it.
Old May 16, 2005 | 03:32 AM
Ryguy's Avatar
sounds like an exaust leak. you will have pore performance and can damage/bend a valve depending on how big of a leak (when shut off cold air seeps in).
black03rcsb
Sep 1, 2015 10:17 AM
superchomper2003
Aug 26, 2015 09:39 AM
V-seriesTech
Jul 28, 2015 12:31 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
