No Spark Questions
Old Mar 8, 2010 | 02:00 PM
WHITEBOY_ZACH's Avatar
Default No Spark Questions
2002 Silverado 1500.
4.3 V6
This is my sisters truck, I really dont know much about it.
I am getting power to the ICM and to the coil, but it will not make spark.
I put a second distributor in and I am pretty sure it is set correctly, but that leads to two questions,... Shouldn't it make spark even if the timing is off? and secondly, could there be a problem in the distributor? (are there different distributors for the V6)
I really dont know where else to start on there,
Any and all help is greatly apprciated.
Thanks alot,
ZACH
Old Mar 8, 2010 | 09:40 PM
53bowtie's Avatar
Is the coil wire firing? You can have power going to the coil but if its not firing then its the coil. If the coil wire is firing then you will have either a cap/rotor problem or plug wires.
Old Mar 8, 2010 | 10:24 PM
Mrgoodwrench3's Avatar
Faulty crank sensor will cause a no spark condition too.
Old Mar 9, 2010 | 11:40 AM
budhayes3's Avatar
PT's Slowest Truck
That's what I was about to recommend and yes, even if the distributor is in wrong, it will still throw spark, only at the wrong time.
Old Mar 9, 2010 | 12:12 PM
CODE4LS1's Avatar
I would check the ignition control module. When that goes bad there will be spark at the coil but not to the distributor.
Old Mar 10, 2010 | 09:37 PM
If the ignition module is working it will command the coil to fire. The coil is connected to the distributor with the coil wire. How are we loosing spark?
Old Mar 10, 2010 | 09:47 PM
CODE4LS1's Avatar
Yeah that was stupid.....I didn't read enough to properly help diagnose this problem and it made no sense. My bad.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
bisqikss
Sep 8, 2015 03:35 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
