No Power?? Sorry this is a little long
Old Jul 26, 2005 | 10:03 PM
  #21
Lightbulb
Are you sure that your valve springs have enough seat pressure?
It's a possibility that your valve springs are flatening out after 5,000 RPM's.
Just a suggestion or thought.
Jim
Old Jul 26, 2005 | 10:45 PM
  #22
rosscob's Avatar
Jim
I am not sure of that, but I did install Comp 918 springs. Is there a way to check the seat pressure on the vehicle?
Old Jul 27, 2005 | 09:17 PM
  #23
Your IAT sensor should be moved to after the S/C. That should help drastically!
Old Aug 8, 2005 | 11:17 AM
  #24
rosscob's Avatar
That is one of my next little projects.
Thanks you everyone for your help!
Old Aug 8, 2005 | 12:56 PM
  #25
MikeGyver's Avatar
I'm running around 6psi. My boost gauge is holds stead all the way thru the entire rpm range... It could be creeping...
Mine runs about 5 psi until about 4500, going up to 6 psi. Power keeps going up until it shifts. If I could find a cable to hook my seat-of-the-pants dyno to my laptop, the graph of the power would show a steady increase to about 4500, then a sharp increase to redline.
Dan Neumann
11
Aug 7, 2022 09:06 AM
ARC
57
Feb 21, 2022 10:54 AM
2500ZL1
Aug 14, 2015 12:23 AM
slowlsx
Aug 10, 2015 05:33 PM
