No forward gears in a 4L80E
Old Apr 27, 2003 | 12:27 AM
99 2500's Avatar
Default No forward gears in a 4L80E
Hi,
Was checking the engine mounts by putting the vehicle in drive and raising the engine rpm's with brakes applied, then I heard a strange noise followed by no forward gears. Reverse still works, any ideas of what the problem might be? The vehicle is a 1999, 3/4 ton, with 6.0 liter and has 77000 miles.
Thanks
Old May 2, 2003 | 11:07 PM
99 2500's Avatar
Default Re: No forward gears in a 4L80E
update:
I took of the transmission, and noticed that the flywheel had a crack in a complete circle around the bolts that hold it on to the crankshaft. I then started to disassemble the transmission and found the area where the hub of the torque converter drives the pump had a big crack in the shape of a Y , didn,t find anything else wrong with the tranny. Cluthes seemed to be in good shape. So I guess the only things I will need is a flywheel, new pump assembly and a couple gaskets.
Old May 5, 2003 | 09:10 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
That is strange.
Old May 6, 2003 | 06:45 PM
99 2500's Avatar
Might have something to do with the 2600hd converter, transgo shift kit set at firm shifts and hypertech programmed for firmer shifts.
Old May 6, 2003 | 06:55 PM
XLR8NSS's Avatar
Adkoonerstrator
Yeah, that could have been the problem. I don't think you're supposed to use the HPP3 firmer trans shift settings with a shift kit installed.
I bet that thing shifted pretty hard.
John
ferrellrooster
Mar 6, 2025 03:22 PM
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Oobray
Jun 13, 2022 03:38 AM
Ammadien
Jul 22, 2015 08:50 PM
MileHighSierra
Jul 12, 2015 12:23 AM
