No B1 Oxygen Sensor
Old Oct 29, 2008 | 07:58 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default No B1 Oxygen Sensor
Well I have no trims, B1 O2 sensor is reading 447 flat. Bought a new sensor from PepBoys and just replaced it, still no B1 O2 reading, just flat 447. Burned my freaking arm good in the process ....I checked the fuses, no luck.
Old Oct 29, 2008 | 07:59 PM
BlackGMC's Avatar
Resident Retard
is b2 oscilating?
Old Oct 29, 2008 | 08:01 PM
trever1t's Avatar
yes, reading 900+ but moving normally.
BlackGMC's Avatar
Resident Retard
so no change at all with the new sensor?
Old Oct 29, 2008 | 08:04 PM
trever1t's Avatar
nope, none! Bad lead to the connector?
Old Oct 29, 2008 | 08:06 PM
BlackGMC's Avatar
Resident Retard
Are you absolutely sure that it is pluged into the correct plug, meaning you might have mistakenly plugged it into the B1S2 plug... It would make sense cause you just had your tranny out a little while ago when this problem arose???
Old Oct 29, 2008 | 08:10 PM
trever1t's Avatar
it's a distinct possibility...I have a ramp but barely fit under this fugger...I need a lift or at least a jack and jack stands. Are the plugs the same?
Old Oct 29, 2008 | 08:12 PM
BlackGMC's Avatar
Resident Retard
on my truck they are, i am not sure about yours... The reason I mentioned it because one of my friends on here (Colton) did the exact same thing.... Stranger things have happened...
Old Oct 29, 2008 | 08:14 PM
trever1t's Avatar
yeah, I'm going to have to get it on the lift, I guess, there are no big curbs around here to get on thanks.
Old Oct 29, 2008 | 08:15 PM
BlackGMC's Avatar
Resident Retard
I hope that fixes it, if it doesn't, I have no clue whats wrong with it...
