Nnbss/tbss
Old 01-27-2017, 04:21 PM
  #21
arthursc2's Avatar
Received 1,436 Likes on 1,063 Posts
Intake; 25383922
Old 01-27-2017, 07:50 PM
  #22
Wolftrk99's Avatar
Originally Posted by 86 IROC
https://sdparts.com/i-22714833-sdpc-...e-bracket.html
Not a "direct fit", I had to do some small modifications. But, it is made out of aluminum and cuts fast. It saved me a lot of time.
What did you have to do to modify it, have kinda been thinking the throttle cable bracket from a cadillac might work, or be made too and seems to have the right offset for the cables in the trucks, just need to remember which year i was looking at...
Old 01-27-2017, 08:05 PM
  #23
10 Second Club
I had to use a file to open up the holes for the cables. And I had to trim off a little to clear the vacuum port on the TB itself. (Which ended up capped off with the catch can. I could have just put a pipe plug in the TB looking back.)
Old 01-27-2017, 11:34 PM
  #24
Wolftrk99's Avatar
I am still toying with replacing my tb eventually, and figure that would be the time to sort out the cables and bracket...
Old 01-28-2017, 02:07 PM
  #25
Kodiak544's Avatar
Anybody got part number for the part number for harness for tbss?
Old 01-28-2017, 02:24 PM
  #26
Gbrown1320's Avatar
What "harness" are you referring to?
Old 01-28-2017, 02:50 PM
  #27
Kodiak544's Avatar
Sry I see it now thought you mentioned it but you where saying cut some of the wrap. So I will need to buy a intake from member on here with rails and injectors or buy flex fuel injectors. C5 filter, 4 bolt tb, silicone adapter to convert to cai and some 3/8 hose. Will there be holes to mount the filter to fuel rails?
Old 01-28-2017, 03:00 PM
  #28
Kodiak544's Avatar
You have part number for non flex fuel rails or engine they come on?
Old 01-28-2017, 03:12 PM
  #29
Gbrown1320's Avatar
I currently have a complete NNBS intake with flex fuel injectors and rails available if it's something you're interested in. Pictures are available in the link posted near the top of this thread. PM me if it's something you're interested in.
In reference to the fuel filter mounting to the rail. In my case, I was able to mount the filter bracket to a small little tab that is on the NNBS rails. I just had to pull the filter canister out of its sleeve and mount and flip it 180 degrees. You have to be very careful running a bolt and nut through the brackets though because it's easy to compress the hardline of the fuel rail right where the tab is located, you don't want to tear through the metal. Alternatively, some people just run the filter directly off the backside off the rail, but it causes the fuel fines to be jammed against the firewall. Here are some pictures from when I was mocking up the filter and loop lines/fittings.
Old 01-29-2017, 11:45 AM
  #30
JDC
JDC's Avatar
Originally Posted by Gbrown1320
Keep in mind, when running the corvette fuel filter returnless conversion on the 99-02 year models, you will need to have your tuner adjust for the transition to a fuel table compatible with a static fuel pressure of 58psi rather than the factory vacuum referenced variable pressure table.
For those interested, here are some images of my chosen method for plumbing the returnless conversion using the vette filter. The way I have mine done keeps the fuel fines from being jammed up against the fire wall and keeps the filter from being wedge back to the back of the engine bay.
As others have mentioned by linking my thread, I keep a pretty constant supply of these intakes and can probably get you setup with the parts you need if you're interested.
Hey how much difference do you think changing the fuel table from vacuum to static would make? Im not sure if mines tuned to static.
