NNBS Throttle Body Differences (2007 vs. 2009)
Old Jul 7, 2013 | 09:46 AM
cmatt's Avatar
Default NNBS Throttle Body Differences (2007 vs. 2009)
So I've done the NNBS intake manifold swap and used a 2009 truck intake and LS7 90mm TB. Now I'm cycling a CEL on ignition cycles with P0101, 0220 & 2135 codes and seeing a reduced engine power message. I've been told the TB is the culprit and swapping to a NNBS 87mm TB should fix the issue.
Looking at the NNBS TBs, there appears to be different part nos. from 2007 to 2009: ACD 2172422 and ACD 2173151, respectively.
So what are the differences and which should I go with for my application?
Full disclosure: I'm also running an Airaid intake tube for a 2009 (to take advantage of the PCV port) and using the stock airbox.
Here's a pic of my current set up because I know we all love pics.
Old Jul 7, 2013 | 09:51 AM
Whitecrewcab's Avatar
Are you using the x-link? They have said with certain throttle bodies, you have to clip a wire. I'd search and see what you can find. I'm using a truck throttle body and a stock x-link and mine works fine.
Old Jul 7, 2013 | 09:59 AM
cmatt's Avatar
I am using one. Based on my reading, a wire needs to be clipped to allow the TB to open fully on some applications. I believe, with mine, I don't need to. I'm using the ACD 2173153 90mm TB.
I did check by watching the valve open fully while I had someone press the gas pedal.
Old Jul 13, 2013 | 09:18 AM
cmatt's Avatar
So I ordered a 2007 & 2009 NNBS TB to compare the two. There's definitely a difference.
2007 p/n: GM 12580760, ACD 217-2422
2009 p/n: GM 12629992, ACD 217-3151
Here's some pics:
2007 on the left, 2009 on the right.
You can see the biggest difference is on the bottom of the opening just in front of the blade.
jdb11386
Dec 3, 2015 09:34 PM
Slammed96
Jul 27, 2015 07:22 AM
fat tony157
Jul 16, 2015 12:35 PM
Blackrat48
Jul 8, 2015 05:28 PM
Gadgetized
Jul 7, 2015 04:40 PM
