NNBS p0108 magnacharger help map sensor
Old Sep 24, 2008 | 01:29 PM
mrb04's Avatar
Default NNBS p0108 magnacharger help map sensor
I am hoping someone can help me. I bought the truck with this problem and cant pin point the problem. The truck has po108 pending after you drive the truck on the highway for a short period of time say 10 minutes. The check engine light never comes on because it resets itself after you turn the key of and on. I guess the problem is not there on start up and you can drive it around town and never have a problem. Anyway I have check for 5 volt at plug and check resistance to ground and appears to be good. I went ahead and replaced sensor hoping that it would fix it and it didn't. Maybe vacuum? Truck has a magnacharger and gm performance intake. Truck seems to run fine but when the code is pending the trans goes into safe mode and shifts hard. Any help thanks
natejk
Nov 15, 2016 08:05 AM
chvy=power
Oct 20, 2015 09:08 AM
chopperloco
Sep 28, 2015 08:40 AM
Pimpinpete
Sep 8, 2015 07:39 PM
