NNBS cam 3 bolt or 1 bolt?
Old Jun 23, 2009 | 02:27 PM
blacklung's Avatar
Default NNBS cam 3 bolt or 1 bolt?
Looing at putting a cam in my 08 nnbs 4.8L. Wanted to see if it was a 3 bolt or 1 bolt? I have been told both ways and just wanted to make sure before I go to get one. Also the truck is a daily driver lifted on 37s. I want it to have a mean sound and wondered if you guys had any suggestions on which cam to use or had any links to guys running them or video clips?
Thanks
Old Jun 23, 2009 | 02:34 PM
sonoma43's Avatar
your's is a one bolt cam, however you can simply switch cam gear's and go with a 3 bolt cam (more options). Dont over cam it with those big tires you will kill what little low end you have.
Old Jun 23, 2009 | 02:38 PM
blacklung's Avatar
planning on gearing it to a 4.88 with the tires and having a wheatley tune done also
Old Jun 23, 2009 | 04:49 PM
blacklung's Avatar
any other help or suggestions?
Old Jun 23, 2009 | 06:49 PM
chevrolade's Avatar
yea yours is a one bolt,,hey bro forgot to mention,u need the z06 valve springs or better,and the ls7 cam sprocket(3 bolt).
Old Jun 23, 2009 | 06:52 PM
sonoma43's Avatar
go with a performance valve spring, not a stock vette spring. ls6 springs were not meant for the ramp rates of today's cam's. they may hold up, they may not, it's a crapshoot in my eyes
Old Jun 23, 2009 | 09:30 PM
hahaha, i figured as soon as you saw some clips of cammed trucks, u would get the bug!! im game for what ever cam u pick bro, i got the tools, and im only about 10 houses down from u!!!
Old Jun 23, 2009 | 09:34 PM
also.....i know you dont want to put a converter in it, so loook at the comp xr265hr, 212/218 522/529 on a114 lsa. It will sound good and healthy, AND your not going to have to worry about drivability, nor a converter.
Old Jun 23, 2009 | 09:50 PM
schino's Avatar
i got part numbers here for ya since parts are sittin next to me. save you some searchin
3 bolt ls7 sproket 12586481
bolts for the sproket 12556127
and youd need a balancer bolt also 12557840
Old Jun 23, 2009 | 10:19 PM
schino, im assuming u did the ls7 cam sprocket as well, thanks for the info, i will be the one helping him put it in, so this info is great, thanks bro!!
