nitrous vs maf lbs/min readings
Old Feb 26, 2004 | 06:51 PM
O3GMC's Avatar
12 Second Club
Default nitrous vs maf lbs/min readings
This may be a dumb question, but I know that s/c or turbo's will up the maf lbs/m just because its pulling more air through the filter+maf, but what about nitrous? Does the increased hp from nitrous make the motor pull more air? Since f/i gets more oxygen to the combustion via air, and nitrous gets more oxygen in via.....itself..........does the motor pull more air in making the maf readings higher?
The last time I had the predator hooked up, the bottle pressure was low (this is a 50 shot - anything less than ~950 does nothing or is too rich) and was reading just a tad higher while spraying vs n/a - about 28 average with a peak of 34 n/a and about 32 average while spraying with low bottle pressure. I havent tested or looked at maf lbs/min while spraying at full bottle pressure.
The n/a runs are a rich factory tune (custom predator nitrous tune) to be extra safe while I'm testing out the nitrous, which may be why both the n/a run and the low pressure n2o run weren't showing very high maf readings
I have heard that you take the maf lbs/min reading X about 10 and get approximate horsepower.........so if it was say, 35 lbs/min, would that mean 350 hp at the motor? or wheels?
Just curious
Old Feb 26, 2004 | 06:55 PM
XLR8NSS's Avatar
Adkoonerstrator
A wet kit shouldn't show any change in the MAF readings but, a dry kit should.
That's why you can run HUGE wet/direct port shots on an these electronics and not worry about maxing the MAF.
lucas287
31
Jan 12, 2021 06:18 AM
simman22
Jan 21, 2017 10:27 PM
Tydriver
45
Oct 23, 2015 09:19 PM
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
