Nitrous upgrade....
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Maxmumboom:
<strong> N.O.S (Nitrous Oxide Systems) makes a cool kit for the mustang 4.6l. its 1 150shot kit that installs between the injectors and the intake man. to supply it with the N20 and extra fuel. I wonder if it can be retrofit onto the ls1motor.
J </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe you are talking about the noszle system which is out for our engines too. It installs between the injector and the intake manifold as you said. It is somewhat expensive and is just a direct port nitrous kit that doesnt require drilling of the intake manifold.
if GMS advertise's there LS1 MAF sensors for trucks/f-bodys then why wouldn't the NX MAF kit for 4thgens work on your truck? I was actually going to use the LS1 Fbody Wet Plate system from TNT, but the only problem with this is the fan schroud is in the way.
the ls1 maf has the IAT sensor on the MAF i believe. i know that the wires for it are on the plug for it. Ours have 3 wires where the ls1 style has 5 wires and also has removable maf ends where ours doesnt. Our MAF is the same design as the ls6 maf though.
Bryan
Bryan
I was just curious as I was looking at getting the GMS one thru Summit. They actually have it listed as a LS1 GMS MAF for LS1 fbodies/trucks. Either I'm not seeing something here or...? GMS also has it listed the same way at there webpage. I would assume it would work with both since that is what they are advertising. So then the number of wires could be diffrent but they might also have the same plug in?
STUB25, I HAVE A GRANATELLI MAF ILL SELL YOU. ONLY USED IT 6K MILES/ 1 YEAR. ITS LIKE NEW AND COMES WITH THE BOX AND INSTRUCTIONS. I WENT BACK TO STOCK CAUSE IM GOING TO GET LS1 EDIT. $150.00 SHIPPED TO YOUR DOOR.
Will the GMS work with the UPD? Everybody on here must be a salesman of some sort everybody trying to sell something on every post!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
