Nitrous or Stall?
Old Aug 18, 2004 | 11:05 AM
TigerFan187's Avatar
Im sorry fo this was already stated I just didnt feel like reading all the post but If you get the Transgo you are supposed to have your line pressure at stock because if it is raised + the shift kit bad things are likely to happen!
Old Aug 18, 2004 | 11:47 AM
Munson's Avatar
i would do nitrous also
Old Aug 19, 2004 | 02:16 AM
OUT2WIN's Avatar
Originally Posted by James B.
There are a lot of close-tollerance mechanical junctions in the driveline. In the torque converter there are splines between the turbine and input shaft and between the stator and stator shaft. In the transmission every steel clutch plate is splined to its drum and every friction plate is splined to its hub. In "drive" the forward clutch pack is engaged all the time and the 3-4 clutch pack is engaged in third gear and overdrive. There are two planetary sets, each with four (4L60E) or five (4L65E) planet gears, each with a sun gear splined to a shaft. From the transmission you have the Slipyoke splined to the output shaft. The yoke has u-joint, each with needle bearings. If the truck has a transfer case add all those mechanical junctions. If the truck has a two piece driveshaft there is a slipyoke and splines there with another U-joint. At the rear end it goes through another u-joint to the pinion shaft. The pinion yoke is splined to the pinion shaft. Then there is the pinion to ring gear lash. inside the differential there is tollerance between the spider gears and their shaft, and lash between the spider gears and axle gears which are splined to the axle.
The point is, there are dozens of places where torque moves from one part to the next connected only by the tollerances between the parts. Setting up the shifts too firm is like turning the driveshaft with an impact gun. Inside the trans you have aluminum clutch hubs and drums splined to steel clutch packs. These aluminum parts do not handle instantaneous torque spikes such as those experienced during jolting shifts. Secondarily, jolting shifts also affect your belt tensioner's life, motor and trans mounts, suspension bushings, and belt life. With violent upshifts the motor drops RPM so rapidly that the accessories overrun the crank with great force. If you could watch the serpentine belt during a jolting upshift you would see the tensioner bottom out to its maxed position and the belt ride up in the groove of each pulley. the accessories will slip on the belt as they overspin it.
The more thrashing the driveline takes the more quickly all these tollerances between parts will losen up and get sloppy. The rear differential and axle splines are the first to suffer since the pinion and ring gear are multiplying the torque from the driveshaft by a factor of the gear ratio.
I don't like alot of play in the driveline. The best way to keep it that way without sacraficing the way you want to drive is setting up the WOT shifts to be civilized and not jolting.
The band in the 60 is wrapped around the reverse input drum. It is engaged by a pin with two pistons, one for second gear and one for fourth (OD) gear. Installing the "Corvette Servo" affects only second gear since fourth is handled by a different piston. Bands are semi-self-energizing. Trying to engage them too quickly will result in violent grabbing and a jolting shift. Some people are amused by the tire barking this causes during the shift, only because they don't understand what an absolute hell this is on the parts. This limitation is one of the factors that holds down any trans that uses bands to shift from smoothly scaling up to higher power-handling. (Incidently, TH400 and 4L80-E transmissions do not shift with bands, they use all clutch packs. Bands in those units are used only for manual overrun or reverse.)
I will always cast my vote for a smooth but firmly shifting trans calibration over a solid jolting setup. Everything will simply last longer and provide a better ride.
Old Aug 19, 2004 | 09:43 PM
only do N2O if you like smokin one tire at about 60 get an LSD 1st
Old Aug 19, 2004 | 11:14 PM
FirstGen's Avatar
I think you should buy a dodge neon...
Old Aug 19, 2004 | 11:25 PM
derek_silvy's Avatar
Why? I'm no mopar fan!
How about a tire smokin' Geo Metro!
:zoom:
Old Aug 19, 2004 | 11:33 PM
FirstGen's Avatar
actually I put a 150 shot on a Geo rental car I had once. I even beat down a mustang GT with it too. The dude's girl was riding shotgun LOL. Did I mention that we also pulled the e-brake on the highway.... To top it all off, when I came out in the morning the Geo had been hit from the rear from my dumb *** neighbor who pulled out of the driveway in a real hurry with a foggy windsheild and nailed the Geo!!!
True Story...
wickedRCSB
Oct 30, 2015 09:45 PM
Miguel199
Oct 16, 2015 08:04 PM
Wolftrk99
Oct 2, 2015 08:17 AM
bisqikss
Sep 27, 2015 09:40 PM
sTNT971
Sep 26, 2015 06:27 AM
