nitrous and shiftpoints
Old Jul 10, 2003 | 10:46 PM
hyper's Avatar
Default nitrous and shiftpoints
i heard that u have to lower your shiftpoints when ur running nitrous. this is really the only thing holding me back from getting it. i want to drive around normal with my shiftpoints how they are. i dont want to have my truck restricted when im not using the nitrous. y is it that u have to lower them?
Old Jul 10, 2003 | 11:05 PM
BigTex's Avatar
Default Re: nitrous and shiftpoints
I kept ma same shift points, but I did raise the rev limiter. With ntrous, you may go a litte past the shift point rpms before the shift happens. By raising the rev limiter, you don't have to worry about hitting it before your shift.
I shift in the 6000-6200 range on nitrous.
Old Jul 12, 2003 | 02:46 PM
graygmc's Avatar
do you have a programmer right now? i just raised my shift points +2 1-2 and +6 2-3 when on spray. also raised limiter to 6200. if you dont have a programmer then the stock shifts points should work fine.
Old Jul 12, 2003 | 03:38 PM
oracleknowledge's Avatar
some programmers, LS1Edit and I think the diablo programmer allow you to edit regular shift points and tow/haul shift points.. Set up the regular shift points for every day fun driving and then set up the tow/haul shift points for when you are on the juice
simman22
Jan 21, 2017 10:27 PM
gavin2005
Sep 13, 2015 09:04 PM
06 4.8
Sep 11, 2015 10:36 AM
gmcyukon
Sep 7, 2015 08:46 PM
06murder
Sep 4, 2015 03:54 PM
