Nitrous with Radix
Old Jun 23, 2005 | 10:13 AM
Last Call's Avatar
TOTM: January 2007
I talked to guy in a nitrous 96 LT1 Impala, running 14.20's on a 100 shot.
He told me he was building an SS with a Magnacharger and nitrous, 100 shot. I thought that was a big shot.
The most I would run is a 50 shot, probably 35 is optimum for realiability purposes.
Old Jun 23, 2005 | 10:39 AM
O3GMC's Avatar
12 Second Club
2toneblown sprayed a wet 50 shot on his radix 5.3 and gained 75rwhp. Although he said something about the head gaskets being nearly shot when they took the heads off. I would just make sure your tune is safe enough. Nitrous + detonation = pop
Old Jun 23, 2005 | 11:36 AM
I heard that you can't run nitrous through the blower or at least it is not good for it. I would think a direct port system would work well with a radix.
Old Jun 23, 2005 | 10:08 PM
BigBlackAv's Avatar
03GMC, how are you going about doing the meth injection?
Thanks,
Damon
Old Jun 23, 2005 | 10:16 PM
SallyDaGMC's Avatar
Thanks,
Damon
I thought I read some where that meth injection and the radix don't match up too good. I probably missed something. I just wanna know cause Im real close to getting the radix and would like to know this info.
Old Jun 23, 2005 | 10:52 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Looking for the same info. 50 shot with he Radix, wey/dry?? Somebody has done it out there.....
Old Jun 24, 2005 | 11:17 AM
Last Call's Avatar
TOTM: January 2007
They say meth is not good because it causes the coating on the rotors to flake off over time.
As far as nitrous, 2toneblown ran a 50 wet shot and he gained 75 rwhp. A guy that F8L knows was running a 75 shot through his radix 6.0 SS silvy and running 12.5's I believe.
It can be done, just have to be careful. A blower backfire will blow the charger right off the intake manifold.
Old Jun 24, 2005 | 11:40 AM
O3GMC's Avatar
12 Second Club
I should change my sig, because I'm probably not going to spray meth, but denatured alcohol or a alky/water mix which is supposed to be alot less corrosive (or maybe not corrosive at all?). I heard about the coating flaking off, but Brian told me that that was just with the older gen eatons. So I think I'm going to try an alky kit and see if I can get more timing out of the tune. I've been trying to decide between the snow performance, alky control or SMC kits......
Old Jun 24, 2005 | 11:48 AM
2toneblown's Avatar
Just put a set of cometic gaskets on your truck. My truck handled it fine. Yes the stock 50K mile head gaskets were almost shot when i pulled the motor apart, but what do you expect from a kid that was out at the street races or track every weekend going through about 5 bottles a week? I was making 475 on stock internals. I personally think it will be fine if you put some good head gaskets on it. LS1s LOVE nitrous
simman22
Jan 21, 2017 10:27 PM
bagged7104SS
Sep 24, 2015 08:42 PM
gavin2005
Sep 13, 2015 09:04 PM
gmcyukon
Sep 7, 2015 08:46 PM
06murder
Sep 4, 2015 03:54 PM
