nitrous and hpp3 tuning?
Old Sep 30, 2002 | 12:06 AM
hyper's Avatar
Default nitrous and hpp3 tuning?
what should u have your hpp3 settings to while running nitrous?
Old Sep 30, 2002 | 08:29 AM
GREGGO's Avatar
Default Re: nitrous and hpp3 tuning?
Depends if you are running wet or dry. If I were running dry, I would take the power tuning OUT. One way the HPPIII works is to lean out the fuel and advance the timing. Lean conditions on a dry shot = BOOM if your not careful. If you run wet, you should be OK as long as you don't have it set where it could bounce off the rev limiter.
Old Sep 30, 2002 | 04:38 PM
hyper's Avatar
so if i have my shiftpoints maxed out and the rev limiter is at 6200. do u think it wil be ok? ..i do have wet btw
Old Sep 30, 2002 | 04:40 PM
hyper's Avatar
i also heard that if u leave the hpp3 at 87 tuning instead of 93, then it wil not advance the timing and your ok.
Old Sep 30, 2002 | 11:53 PM
graygmc's Avatar
i didnt have my shift points maxed out when spraying. they were at like +4,+9,+0. that would be the safest way. i think tuning would be ok up to a 100 shot also.
Old Oct 1, 2002 | 12:02 AM
Well hell here we go myself and Mix have or had ours on 93 tunning, but we always run AV gas when spraying and we spray bigger than 125....Lots bigger...lol
X_Racing1
21
Mar 30, 2016 02:37 PM
southernsmoker
Aug 31, 2015 03:09 PM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
