NITROUS HELP
Cuz I AM a BADMOFO
I currently have a 2000 ECSB with a magnaflow cat-back and a HPP3. I would like some information on what types of Nitrous systems anyone may be running. Are the kits for the trucks dry systems? Where does the nozzle install? Also, will I be able to use my Hypertech programmer? Some one told me I could use it for the trans upgrades but not the 93 tuning because that advances the timing. What kind of performance gains can I expect to acheive with this addition? Thanks for any help.
Most of the big nitrous companys make kits for the trucks. Putting a dry system together is simple.
Bottle & mounts
supply lines & adapters
nozzle w bung adapter
nitous cylinoid
WOT switch
"spray" button
wiring
That's a basic kit. You may want to add a heater, window switch, and pressure gauge (at least on the bottle)
The nozzle on a dry kit will go infront of the MAF past the filter. Most guys don't run the 93 when spraying. I did and I think that contributed to my
Good luck and keep the questions coming.
Bottle & mounts
nitous cylinoid
WOT switch
"spray" button
wiring
Not trying to promote Nitrous Express, but I have dealt with them before, and they are fantastic, and their kits include everything you could want, check out their email address. They have great tech guys that will answer all your guestions, without makeing you feel like an idiot in the process.
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
