Nitrous???? 5.3L
So I wanna get a Nitrous kit for the extra HP, i wanns run a 125 shot. Nitrous is one thing that i have not done and have not really read too much about. I am good at installation and all so i will install it myself. What kit should i get??? How much does it run??? How hard is it to install?
I have heard many good things about the nitrous express kits, thats what i'm going to get in the future and probably run a 125 shot as well, I'm getting a wet kit. With the wet kit you should also look into getting a fuel pressure regulator switch, Wide Open Throttle switch (the NX kit comes with this) and you might want to run a rpm activation module so you can set it up to not spray when you shift. The NX wet kit is about $590 and comes with everything you need, including the WoT switch. It doesn't come with the rpm activation module or fuel pressure regulator however.
Hope this helps
Hope this helps
I'm running a home-made dry shot on mine. Here is a link to some info on it:
https://ls1tech.com/forums/showthread.php?t=229251
It feels REAL good on the street, although traction is really an issue. I'm going to the track on Sunday, so I'll let you know exactly how much I get out of it.
I have a TNT F1 kit(75-150hp wet kit) and the fact that it has 2 nozzle with 4 jets in the power ring going over your throttle body to me makes it superior to others but I dont have experience with others. The guys at TNT told me that I should get 107rwhp with a 100 shot and I cant remember the tq #'s but they were good! Go with TNT or NX they seem to be the most used on this site!
I have a dry shot on mine, I gained about 130 rear ft lbs of torque & 100 rwhp on a nos 120 shot, this with 22 degrees of timing. The install was fairly simple when I first put it in it took all of an hour. It was very clean but I did it just to make sure it worked. It took about 2 hours to clean it up with the switches. If you have any automotive knowladge at all it would be a breeze, I cannot imagine paying anyone to do it. I would put it on the same leval as installing an amp.
from what i understand NX rates their kits at the tire nitro daves who i now believ is nitrous express in the manufacturer link >>>>>> sells something i think for like 690$ somewhere around there with a pressure gauge and such as well that is what i would do. keep in mind again that NX rates at the rear tire i believe friend running one gains (on a 100 shot) 100 hp and like over 120 tq hope this helps
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
