NGK tr-5 plug gap
Old Mar 25, 2005 | 10:34 AM
12 Second Club
Default NGK tr-5 plug gap
hi guys,I bought a set of tr-5 plugs for my '02 2500hd.my question is what should they be gaped to?? I did a search and found that some say to use them right out of the box and others say gap them @ .050 or .055.I checked them out of the box and they are like .040.help me out here please.BTW truck is 100% bone stock.
Old Mar 25, 2005 | 10:35 AM
marc_w's Avatar
I don't think it will make much of a difference...
I put mine in at .050. Ran them until they were at .060, 20,000 miles later... and then regapped them to the 2004 spec. I forgot what it is right now, but I think it's .040.
I can't really say I remember feeling a difference.
Old Mar 25, 2005 | 10:47 AM
12 Second Club
I was kinda thinkin about just gapping them at .050 and split the difference.
Old Mar 25, 2005 | 10:55 AM
marc_w's Avatar
That's a good idea... can't go terribly wrong ether way.
Old Mar 27, 2005 | 09:58 PM
12 Second Club
anyone else have any in-put on this ??
Old Mar 27, 2005 | 10:17 PM
02sierraz71_5.3's Avatar
I think stock gap is .6 but I could be wrong for the 6.0 motor I wouldnt go more than .6 or less than .5 unless you have raised compression or running nitrous in that case I would get a lower temp plug like a 6 or 7 depending on the shot your running or how much compression you have and adjust the gap from there.
Old Mar 27, 2005 | 10:21 PM
I just read your sig I would go with the factory gap I believe those plugs are almost identical if not the same as the ones gm is using. Ive seen ac delco plugs come out of gmc's that say ngk on the other side
Old Mar 27, 2005 | 10:34 PM
GREGGO's Avatar
The only thing a .005 or .010 smaller gap on a stock motor will do is possibly cause a random misfire code once in a blue moon. I ran a .055 on my TR5's with no problems.
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
