Next move
Old Dec 29, 2011 | 07:05 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by youngbuck
Think these heads are choking it any?
Not with a stock cam....
Old Dec 29, 2011 | 09:29 PM
youngbuck's Avatar
What about once I cam it?
Old Dec 29, 2011 | 09:37 PM
Mangled03gmc's Avatar
Baltimore Whore
No you should be fine if that is the valves that have been put in it.. If they were stock then yes I do think it would def be a issue..
Old Dec 29, 2011 | 10:42 PM
youngbuck's Avatar
Ok good. My compression is kinda high, so I'm only running 4° of timing right now. I was told a bigger can will bleed of some compression , then I can add some timing. Also looking into getting e85 setup. Truck made 282 rwhp an 350 ft lbs.
Old Dec 29, 2011 | 10:55 PM
LS1TRUCKGUY's Avatar
with a 4k stall, you could easily get away with a cam in the low to mid 230's duration. IMO 4.10 gears are a great all around gear. what does your exhaust consist of?
edit:
i just read your sig... i would order some tsp 1 7/8" fbody longtubes....
Old Dec 30, 2011 | 08:30 AM
youngbuck's Avatar
I'm only revving to 6k right now, I would like to stay under 6300 as this is my dd. I know a 230s duration loves higher rpms an I dont sent to have a cam go to an rpm range I don't want to spin to lol. Will those headers fit my swap? I would love headers but I'm worried about them clearing my front diff an frame. Thoughts?
Old Dec 30, 2011 | 08:50 AM
You are 4wd? Im not sure, but I don't think they will clear on a 4wd. If you "under" cam it, you will blow right through the efficiency range of the cam with that 4k stall. I daily mine and it sees 6750 rpm a few times a week.... I wouldn't worry about spinning that high
Old Dec 30, 2011 | 08:54 AM
Im pretty sure the ebay longtubes longtubes everyone is getting clear 4wd, but are only 1 3/4" primarys
Edit: not sure if they will clear obs trucks...
Old Dec 30, 2011 | 10:02 AM
Bama2door's Avatar
The only LT's I know of that might fit a ls swapped OBS are the Schoenfeld headers. But I've only heard of them fitting a 4wd that had a 6" lift...so it might be kinda risky
Old Dec 30, 2011 | 11:47 AM
youngbuck's Avatar
My stall won't flash quite as high with 4.10s right?I heard the same about needing a lift for the schoenfield. I've been thinking about trying some of the ebay nbs 4wd headers, my truck looks about the same as the nbs with the diff location an all. thoughts?
