Next mod?
Old Mar 10, 2005 | 03:53 PM
CHAGO's Avatar
Default Next mod?
So far I have:
-custom tune (which Allen is going to tweak for me next time he's in Houston)
-ASM LT's
-no cats
-Corsa exhaust
** I plan on making my own true CAI, so no need to mention intakes.....
So what do you guys think I should get?
Cam?
Nitrous?
Pulley?
Old Mar 10, 2005 | 04:02 PM
Originally Posted by ILLNALI
So far I have:
-ASM LT's
-no cats
-Corsa exhaust
Cam?
Nitrous?
Pulley?
HEY MAN I REALLY DONT HAVE A SUGGESTION FOR YOU CAUSE I AM AT THE SAME STAGE YOU ARE, BUT I DO HAVE A QUESTION. WHERE DID YOU GET THE ASM LT's IF YOU DONT MIND ME ASKING.
Old Mar 10, 2005 | 04:05 PM
CHAGO's Avatar
got them used from another member on the board awhile back
Old Mar 10, 2005 | 04:07 PM
FILE's Avatar
Get yourself an ASP pulley. It's a fairly cheap mod and it's worth about 10rwhp. After that I would get a cam.
Old Mar 10, 2005 | 04:24 PM
rgvsierra's Avatar
asp pulley and 05 e-fans.
Old Mar 10, 2005 | 04:29 PM
CHAGO's Avatar
the crank pulley right?
Old Mar 10, 2005 | 04:30 PM
BLACKND's Avatar
Santiago,
What are you going for. Do you have any trans mods yet? E-Fans? If you are looking to drag it a little. Not sure what all you can do to the trans in your truck, but if so, I would shift kit, servo, and add a stall. It would really make it come alive. I think that was the best mods to date for my pig. Other than that I would get e-fans and a pulley and then a cam. Did you get the lift off?
BTW: When is Allen planning on coming down? I will need him to update my tune once my damn ASM's come in and I throw in the cam.
Old Mar 10, 2005 | 04:50 PM
zippy's Avatar
i would recomend going for a converter and some shifting mods.
Old Mar 10, 2005 | 05:06 PM
lm7's Avatar
lm7
second on the converter and SK, billet servos...
Old Mar 10, 2005 | 06:00 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Converter. With that and your other mods you should be in the mid to low 14's. I think a converter is the best mod to do for these trucks...especially the AWD trucks. You should be able to get into the high 13's with a converter and a couple other small mods. You already have the Long Tubes, custom tune, 6.0L, and traction (on me), so I would think low 14's anyway...even with the 22's.
