Newbie with cam ?s for L9H.
I've gotten a 2013 CCSB 4x4 3:73s. Looking to do a cam swap with talking to ak2007r6 he told me that I would get better off checking out this forum for info. Now to the truck specs......I've got a leveling kit with 33" A/Ts and a Hypertech tuner now. I know that once the swap is done I'll have to have a custom tune for her. I use this truck to pull a travel trailer and such things(DD) like that so I'm not really looking to make a lot of power on top end. I would like to have more torque on the low-mild range. I've talked to the guys at Comp Cams and they said I should use COMP Cams: XFI™, 263PHR14<Br>Excellent Response, Low End Torque, Good Power Gains since I would like to keep VVT and use COMP Cams: Beehive™ Valve Spring: Top 1.075" O.D., .650" I.D.; Bottom 1.310" O.D., .885" I.D. valve springs. My ?s are.....Is there a better cam to go with to make me better low end torque? Is this something I can do at the house with just a weekend? Will this cam have a somewhat close to idle sound? I would like it to be a red light sleeper.
Thanks for any info yall can give a newb!!
mag13L9H
mag13L9H
Check out the vvt swap thread in the gmt900 section. I think that cam is a good choice, or you could go custom grind. Install is not difficult at all. Post up specif questions or pm me and I can help ya from my experience.
lawhitediamante
Aug 12, 2015 12:14 PM
