Newbie Cam Help
Old Aug 30, 2006 | 06:13 PM
06darkness's Avatar
Question Newbie Cam Help
I'm new here and i have a 2006 5.3 crew cab....Mods so far i have stainless works longtubes,high flow cats,magnaflow tru-x,true duals with 40 series dumped,and a volant intake..What is the best cam to run with my setup? Eventually im going with the radix setup also...Can i keep my stock springs or if not how hard are they to change? Any help appriciated...
Old Aug 30, 2006 | 07:15 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Look at these:
Vinci truck cams
Then decide do you want to shift higher than stock, is it a daily driver, are you going to get a torque converter with a higher stall, do you want low end TQ or high end HP, stock or choppy idle?
All this will affect your cam choice.
The "trucker" (see link above) is a good choice or the GT2-3 if the Radix is in the near future. Do a search for the GT2-3 and read up on it.
Welcome to the site
Old Aug 30, 2006 | 09:43 PM
if you are planning on going FI in the near future you might look at the tried and true GT2-3 cam.
Old Aug 31, 2006 | 12:05 AM
06darkness's Avatar
I want a choppy idle and it is a daily driver and about the torque conveter...I most likely will upgrade the trans and covn....all at the same time down the road....i was going to run a 100 shot but not sure....
Old Aug 31, 2006 | 12:12 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I would reccomend the GT2-3 but no chppy idle.
Old Aug 31, 2006 | 08:09 AM
litreddevil's Avatar
Banned
you would have good performance out of the 01 z06 cam
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
supersportsteve
Jul 4, 2015 12:02 PM
