New Throttle Body?
Old Oct 26, 2010 | 09:33 PM
3406a's Avatar
Default New Throttle Body?
I was thinking of switching out my stocker for a new one but i'm unsure which one to go with. Considering my mods below would you guys suggest it and if so which one should I go with?
Old Oct 26, 2010 | 10:11 PM
brent5631's Avatar
Keep the stock one.
Old Oct 26, 2010 | 10:54 PM
blsnelling's Avatar
Are you going with a bigger intake? If not, what's the point of the new t-body?
Old Oct 26, 2010 | 11:05 PM
3406a's Avatar
Ya I would like to go with the 90mm setup in the future but i'm thinking maybe I should just do that all at once.
Old Oct 27, 2010 | 12:43 AM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Don't waste your time with buying a bigger one, just Port & Polish your factory one. It's really esay to do. Do you have a Dremel with a drum sander attachment?
What I did was buy a new take off tb from Ebay & P&P that one. On the inside of it, it's kinda a rough cast that needs to be smoothed out and make it almost a mirror like finish,as well as it has some ridges in front of & behind the blade that need to be sanded down. If you want to go trick, knife edge the blade.
http://www.ls1
howto.com/index.php?category=0
Where this how to says to fill in the hole with putty, body fillr or epoxy, I just stuck a pencile in there(to keep the hole) and filled it in with that quick metal stuff that's a 2 part system where you mix both parts together & it hardens. It's kind like JB Weld
Old Oct 27, 2010 | 07:40 AM
blsnelling's Avatar
If you went to a TBSS intake, or a FAST 90, then would be the time to upgrade. Otherwise, leave it be.
Old Oct 28, 2010 | 05:07 PM
3406a's Avatar
Default Mass air sensor
So I filled in the gap on my spare throttle body and polished it. Was their any certain size that the holes are supposed to be? Is their an easy way to knife edge it? What about my mass air sensor. Is their any way to get more flow from it?
Old Oct 29, 2010 | 05:29 PM
3406a's Avatar
Anybody?
Old Oct 29, 2010 | 10:06 PM
budhayes3's Avatar
PT's Slowest Truck
Don't mess with the MAF, most guys cause more harm than good when they descreen them, and the aftermarket MAF's are also problematic.
natejk
Nov 15, 2016 08:05 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
OHsixLS3
Sep 25, 2015 11:20 AM
99bluefirebird
Sep 17, 2015 08:05 PM
