new silverado owner
Old Oct 24, 2009 | 02:53 PM
mavereq's Avatar
Registered User
Default new silverado owner
new guy here. i recently bought an 09 silverado 1500 with the 6.2L and have been snooping around at what mods are out there. i've been a ford guy for a long time so this is all new to me. i look forward to learning a lot and hopefully getting some good advice from you all.
i am definitely planning on upgrading the exhaust. the stainless works setup is about the best i've seen so far. does anyone know of any other kits that are nice?
i'll eventually put some type of forced induction on the truck. i'm not sure which route, but i'm leaning towards whipple as i have a whipple 3.4 on my drag car that i'm finishing up.
does anyone know of a good tuner in the northern alabama area?
Old Oct 24, 2009 | 08:51 PM
L7 Sierra's Avatar
Get a Mangaflow exhaust even if you just weld in a muffler with your stock piping.
Manga Charger TVS 1900 for a stock engine or 2300 if you wanna go further. Alot further. If I was married I would have me a 1900 tommorow.
Black Bear or Wheatley are tops. Das Bear does tours so if he gets close get a spot. Or his website is to the right here. http://www.blackbearperformance.com/
Old Oct 24, 2009 | 09:24 PM
2005 Silverado's Avatar
SPAM HUNTER
Welcome should be a fun setup to start with, i see alot of people with magnaflows, everyone i know with their mufflers has drone, and they dont sound that good.
I say Corsa
Old Oct 25, 2009 | 01:36 AM
006rcsb's Avatar
i have a magnaflow and mine doesnt drone at all...but its a 24" long case, it sounds great to me! now the flowshmasher that was on there, thats another story, it sounded good but drone was insane. corsa is a great brand also like magnaflow its a straight through style muffler also.
Old Oct 25, 2009 | 02:13 AM
03chevyroyce's Avatar
flowshitter
jk i would run a magnaflow or corsa if i were you
good luck with the mods
Old Oct 25, 2009 | 08:06 AM
lady3bglover's Avatar
Flowmaster here with DMH remote cut out.
Old Oct 25, 2009 | 08:26 AM
SweetS10V8's Avatar
Comp Cams has a cam for 6.2Ls that made 70 more HP and didnt loose any torque.
http://www.gmhightechperformance.com...all/index.html
Edit: I fixed the link...
Old Oct 25, 2009 | 10:03 AM
budhayes3's Avatar
PT's Slowest Truck
ARH makes a nice long tube header system for the GMT900 trucks, and you can couple that with a Magnaflow cat back. I drove tdrumm's 03 rcsb with a Magnaflow cat back for a few weeks and it had zero drone. I like the looks of the graphs posted above, but I couldn't get the link to work...could you post the cam specs?
Old Oct 25, 2009 | 08:56 PM
SweetS10V8's Avatar
It says 222/236-degrees of duration, .566/.578-inch lift and 114LSA.
Old Oct 25, 2009 | 09:38 PM
BuyAmericanIron's Avatar
I put ARH headers with cats on my truck and there was no need to change the muffler or exhaust. It is quiet when cruising and loud when you get on it. For normal driving around town, it has a deep throaty sound with a bit of a growl. These were also the easiest set of headers I have ever installed. Piece of cake and the "Y" pipe bolted right up to the stock exhaust. Welcome to PT! Have fun with your new truck. Now that you have a GM, you will probably never look back to Ford.
