new Posi
Old Oct 10, 2004 | 11:17 AM
bigbody's Avatar
Default new Posi
My friend is about it install a new aftermarket posi diff. He already had the stock G80 in his truck but he just got the new posi for a good deal an plus its stronger. I wish I knew what brand it was, cause that might help. But here are just a few question I had.
Will he feel much of a diffrence with the aftermarket one?
Or will it even change the performance of the truck?
An my other friend just changed his fluid out of his rearend an replaced the diff. cover gasket on his 03 scsb, with 3:73s an G80. But he just put some regular cheap fluid in there, an it seem to be doing ok. I thought you were only suposed to put some special fluid in there?
So what would it do to a readend with the wrong fluid, or does it matter?
Old Oct 10, 2004 | 11:20 AM
snoman's Avatar
What rear end he has would tell you how strong it is as G80 in a 10.5 inch 14 bolt or a 11.5 inch one is a LOT stronger than one in a 10 bolt. Did he get a mechical locker maybe?
Old Oct 10, 2004 | 11:41 AM
one03sierra's Avatar
Formerly one92rs
Talking
if he went eaton then yes he will feel a difference. they lock up a lot better.
Old Oct 11, 2004 | 12:08 AM
bigbody's Avatar
Sorry about that, He just has the regular 10 bolt rearend in his 03 silverado. I think he got a Eaton or Auburne, or something like that. I belive it one of them to, but im not positive
Old Oct 11, 2004 | 05:34 AM
snoman's Avatar
If he got a Eaton, that one is end user rebiuldable while the Auburn is not.
Old Oct 12, 2004 | 08:52 AM
bigbody's Avatar
What about the fluid type. What is the diffrence?
Old Oct 12, 2004 | 09:33 AM
snoman's Avatar
Auburn does not care and the Eaton should have LSD rated flluid because of its clutch plates.
Old Oct 12, 2004 | 01:20 PM
MacADaYear's Avatar
Eaton advises to use stock fluid with the LSD additive. Just dont use synth, atleast thats what the instructions say
Old Oct 12, 2004 | 01:47 PM
snoman's Avatar
That is basically what I said because a LSD rated fluid is the same as a standard EP lube with a additive. There must be a echo here.
Old Oct 12, 2004 | 01:49 PM
MacADaYear's Avatar
You wanna take this outside old man? Lol, seriously get off my nuts before I bitch slap you back into that corner you call a reitrement home
You didnt say anything about the synth fluid, and if you think you wanna take me on, bring it old timer
