(New Kid) have some motor questions
This is simply not true. Flowmaster designs, tests, and proves its products under real world conditions in the dyno cell, at the track, and on the road. All of our mufflers have been designed to provide performance gains when properly installed and used in the correct vehicle application.
Former Vendor
Yes, Flowmaster engineers have designed each series of mufflers with maximum efficiency in mind.
newbe
do your headers and a real dual exh, you should move to the factory
larger rad with dual E-Fans , 170 deg stat also. get a good tune
wires and plugs would prob help if yours are still original factory ones.
CAI of course.
CAI of course.
https://ls1tech.com/forums/dynamomet...they-suck.html
and for those who will ask here:
Home Built Muffler?
K-5 on the Waterfall - YouTube
Former Vendor
Coming from a guy that just built up a 6.0 that cost over $4,000 I think if I did it over again I would just turbo my 5.3 as they are cheap if they blow. My next plan is to turbo my LQ4 but I guess whats your budget. LS motors get expensive really fast.
nice more marketing material... couldn't even try to discredit my post because you know its true.
so the delta flow plates don't impede the flow of hot exhaust gas?
also threw that pic in autocad to measure the inlet and the tube that runs from the front chamber to the delta plates, and that tube is nearly 6% smaller then the inlet and outlet.
also when i ran one on my old truck it droned like a **** at around 1500-2200rpms. basically cruising speed. i thought your engineers spent time and money to lessen drone. i know when i went with a spintech/pypes race pro the drone was a lot less.
at least i know with my magnaflow my pipe is the same diameter all the way threw and is stainless steel so i don't need to worry about it rusting inside out.
