new guy ready for mods
Old Jun 15, 2006 | 07:50 PM
  #21
nightrunner's Avatar
Mr. Obvious
only thing with front mount turbos is they make your underhood temps HOT
Old Jun 15, 2006 | 08:42 PM
  #22
Quik's Avatar
5 year bitches!
Originally Posted by RandomHero
I seriously doubt that. That big of a shot of nitrous would take off about .8 seconds give or take. That means you'd have to run a 13.8 or so without the spray.
I larger cam, stall, good dyno tune, headers and gears will probably get you to a 13.8(if your lucky) but thats about:
cam-600
stall-500
tune-450
headers and exhaust-400(at least)
gears-500
plus the nitrous which is at least $500
Roughly $3 grand JUST FOR PARTS
that is only for parts of course and the install for the cam and stall can run you up close to a grand for both and a another couple hundred for the gears.
If you did it all yourself with NO room for error you might be able to but that would be pretty damn hard
i ran 1.2 seconds faster and 10mph with a 75shot last year and i was letting off the juice around the 1000' mark, buddy did the same thing except only gained 8mph with a 75 shot
Old Jun 15, 2006 | 08:56 PM
  #23
Mr. Obvious
IMO the best way to get 12s and have room for improvement later on, cuz you will want to, its inevitable is...
6.0L LQ9 swap
FLT Level 5 4L65e - to handle all this power, if you go the the third stage I mention, you should probably get a 4L80e conversion
lt headers
off road y-pipe no cats
3 in pipe to magnaflow muffler dumped
cold air intake
descreened MAF sensor
MSD spark plugs
NGK plugs
MSD blaster coil-packs
4.10 LSD rear gears
good hooking tires
dyno tune
TR220/220 cam or bigger
then later you can put on a bigger cam and some performance heads
then after that you can do a forged 408 stroker for the 25+ psi of boost that the huge turbo that you put on it can put out
Old Jun 15, 2006 | 09:41 PM
  #24
BADMOFO's Avatar
Cuz I AM a BADMOFO
I've got a simillar truck, and have a Magnaflow Cat-back, AEM intake, and TT3000 converter. I ran 14.57 with the Hyperterch programmer, which is a far cry off what you're looking for. I also ran the same mods with a 100 Dry shot and it went a best of 13.43. I haven't ran it yet with the 6.0L. I would think about the Radix. I know that the Breeze ran in the 12's with his longbed and 5.3 with a few other boltons and stock 5.3 motor, ie. NO CAM or HEADS with the RADIX. I would expect simillar times from an ECSB.
Old Jun 18, 2006 | 08:42 PM
  #25
CNE's Avatar
CNE
So, if I had $5,000 to play with, should I go with a turbo or supercharger, or internal engine mods for the most power? I was thinking cam, exhaust, cold air, tune and turbo or S/C. I know I can't do all that for 5k but I might start with the turbo. I have a spare 5.3 I could build while I play with the turbo on my other engine. What are some realistic 1/4 and 1/8 mile times with turbo only.
Old Jun 18, 2006 | 09:06 PM
  #26
Mr. Obvious
for $5k on a 5.3 i would do:
pacesetterLTs and ORY and magnaflow catback 1k
cai 300-400 disregard if going with turbo
nelson mail order (unless you are close enough to him to get dyno tune) 400-500
4.10 lsd gears 700k installed
thats about 2.5k right there and save your money if you want forced induction cuz you will need a different cam for fi than n/a
i would go turbo if going fi but n/a has better bragging rights i think
sts is only 3k for base system so i would probably do that plus they have financing
a supercharger needs full exhaust system first for full production of power..
read the sticky in the forced induction section on types of forced induction
it will help you make your choice
Old Jun 18, 2006 | 09:07 PM
  #27
Mr. Obvious
adn if you do a turbo or supercharger you will need to upgrade your tranny
Old Jun 18, 2006 | 11:36 PM
  #28
Exclamation
cam-600
stall-500
tune-450
gears-500
A member here named TxSilverado has a 01' or 02' ECSB 5.3L running a 13.8 in the 1/4 with stock heads, stock cam, and no power adder. All natural aspirated. The heads are O.E. never taken off the engine.
His mods: custom tune, TB stall, CAI kit, LT's, and accessory pullies.
A ECSB 5.3L can be easily pushed into the 12's with NO2. Though not my choice of a power adder.
It just depends on your choice of the right combination of simple bolt-on parts and a good well known custom tuner.
A custom Nelson Tune wins my vote!
Jim
Old Jun 20, 2006 | 04:21 AM
  #29
disturbedsol's Avatar
Has anyone got or know of anyone that's running an ATI Procharger? I was considering buying one until I joined this forum and no one really mentions them. Am I better off going with a turbo? 04 ecsb 5.3
Old Jun 20, 2006 | 01:06 PM
  #30
Charged_5.3's Avatar
It all depends really. How much power are you looking to make?
