new engine/wich cam
Old Sep 25, 2007 | 05:18 AM
primal1's Avatar
Default new engine/wich cam
i'm putting in a new long block in my 99 tahoe with a l31. i need a cam that will allow me run the stock ecm programming until i can get it flashed. it is my daily driver, but i want a little more low end. i think at the same time i'm going to do the spider injector and v-max intake.
Old Sep 27, 2007 | 03:14 AM
primal1's Avatar
anyone?
Old Sep 27, 2007 | 10:44 AM
mds2004's Avatar
VMax intake is worth it. When you get a cam you will need +.50 locks and retainers with stiffer valvesprings such as Comp Cam 918s and also harder pushrods.
You have a heavy vehicle and note that rev limiter is at 5800rpm un;ess you change to a newer van PCM.
Well I have the cam in my sig for my 383, and I still believe it is a little large for that.
I would suggest going with something like a 206/212 112LSA from Comp Cams. I believe the # was 500-08 or something like that, it has been a while.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
