new 6.0 swap. down the drain
Old Jul 29, 2004 | 07:42 PM
Ryan23silverado's Avatar
Oh ya, melting a plug makes the ground strap open in gap size. (right?)
If it closed like that on its own...check for piston clearance
Old Jul 29, 2004 | 08:27 PM
parish8's Avatar
single digit dreamer
i have been told detonation can push the ground like that. number 7 is always the first to go, is it really running fine with just a plug change? i would expect a broken piston.
could you hear any detonation?
Old Jul 29, 2004 | 09:14 PM
2003blue5.7's Avatar
what is the best software for loging?
Old Jul 29, 2004 | 09:24 PM
11 Second Club
I would warm up the truck and fill that cylinder with air see if you hear air in the oil pan. If you do there is something wrong with the piston or rings.
Old Jul 29, 2004 | 09:49 PM
Gordy M's Avatar
Ease software is the best and most full featured, ELive is good, HPTunes is good and Autotap is fair.
Old Jul 29, 2004 | 09:58 PM
do you have ease? Do you think I could check yours out?
Old Jul 29, 2004 | 10:00 PM
parish8's Avatar
i think you will get the most support around here with efilive.
i had a copy of ease about 1.5years ago. it was barely better than atap back then. they probably have something better now.
Old Jul 29, 2004 | 10:11 PM
i use autotap, but i would go with efilive if you don't have a logging program yet (efilive takes many more readings per log than autotap). OR if you need a tuning program AND a logging program i would check out hptuners
Old Jul 29, 2004 | 10:13 PM
bigguy75inches's Avatar
i heard no detonation, and the truck seems to run fine now
Old Jul 29, 2004 | 10:57 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
What kind of RPM were you turning the motor to when it happened?
