New 350
Old Mar 5, 2010 | 04:24 PM
bluelq4's Avatar
Exclamation New 350
ok so i just got a 350 out of a 97 pick-up i just looked up the casting numbers and it says.
its a 4 bolt main GEN 1 crate motor with ZZ4 roller cam. i am currently rebuilding the heads, i am gonna port and polish them and get heavier springs.
i am gonna rebuild the motor, after it is rebuilt i will be selling it.
i will also build the motor for you if your intrested pm me.
Thanks.
Ben
Old Mar 5, 2010 | 07:26 PM
Coban's Avatar
This is not a classifieds section.
Old Mar 5, 2010 | 07:49 PM
YenkoST's Avatar
The '97 Truck 350 engine was a L31 with a 192/197 camshaft...far from the zz4 cam specs of 208/221. Plus the compression on the L31 is 9.4:1 to the ZZ4 of 10:1 as well as the zz4 having aluminium heads to the L31 vortec cast iron heads.
Old Mar 5, 2010 | 08:40 PM
1Bear's Avatar
I'm with you, but if someone was to just look up the casting number, than indeed the same block casting was probably used for both.
hodge9386
Oct 25, 2015 01:26 PM
wickedRCSB
Oct 10, 2015 09:29 PM
gmcyukon
Oct 3, 2015 11:03 PM
ice17
Sep 22, 2015 05:18 PM
cousblake11
Sep 9, 2015 06:52 PM
