Nelson Performance with Radix
Everyone that has the Nelson Performance with Radix, Did you guys remove the superchips program and put it back to stock or just leave with the superchips program installed???? Before you sent the PCM to Allen???
It doesn't matter. Allen will send you a new PCM, with his own tuning in it. The superchips programming is vin specific I believe, which makes it a nice paperweight, or door stop if it isn't windy there.
Originally Posted by Silverado03
One more think how the hell do u remove it from the truck. I got the cables off do I need to remove the battery and the nuts???
Removal should be pretty straight forward, just look at how it's under the hood. Black cover comes off and remove the harnesses.
I'd disconnect the battery as a safety idea to prevent toasting that new PCM...would you want two useless paper weights then?
LOL!!! Thanks I got the dam thing out. It's going to TX to get some real tuneing done...Thanks
gaps
Oct 15, 2015 02:53 PM
gavin2005
Sep 13, 2015 09:04 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
