Nelson Harness
Old Apr 11, 2006 | 09:00 PM
HD6.0l's Avatar
Banned
Default Nelson Harness
Anyone who has the Nelson harness and have or had problems with large draw on the Alt when A/C is on , lights flickering with A/C clutch cycle , Alt gage dropping when A/C clutch cycles , here is a diagram that will cure the problem .
I have a 2005 1500HD (3/4 so no e-fans) and did the 2005 fan install and Nelson harness , the Nelson harness is designed for LS1 or Flexlite fans and not the 2005 stock fans , so the harness does not work to well , but with this diagram the 2005 fans work great .
Old Apr 11, 2006 | 09:31 PM
SnakeOiler's Avatar
Second relay from the left - why?
Old Apr 12, 2006 | 12:01 AM
HD6.0l's Avatar
Banned
Upstream or downstream of the fans , one relay acts as a converter so to speak , converts 12 volts (+) hot to a (-) ground trigger , the fan modes are, NOTE FOR 2005 FACTORY FANS , they draw alot of amps when both running on high speed . MAY NOT WORK FOR LS1 OR Flex-A-Lite FANS
1.No temp , no A/C no fans
2.No temp , A/C on 2 fans low
3.Temp , A/C on 2 fans low
4.Temp , no A/C 2 fans low
5.Exterme temp , no A/C 2 fans high
6.Extreme temp , A/C 2 fans high
I did not design this harness it was actually designed by RedHeartbeat , he used a diagram posted by Aklim on LS1truck.com .
This is designed for a 2005 PCM with the ability to have two PCM pins activate it , pin42 low temp and pin 33 high temp , one could use the high temp pin wire as a trigger , triggered by a high pressure switch or sending unit .
GM
Old Apr 12, 2006 | 05:55 AM
SnakeOiler's Avatar
I see. My understanding of pin 33 was incorrect.
Old Apr 12, 2006 | 10:23 AM
thunder550's Avatar
High on diesel fumes
Does it draw enough air through the condenser when the fans are on low to keep the a/c cold? I would like to keep the high speed from cycling all the time, but I want to make sure the a/c still works well in the 115* summers here....
Old Apr 12, 2006 | 02:53 PM
HD6.0l's Avatar
Banned
To be honest I have not used the setup in hot weather yet , but the way the fans run are just the way a 05-06 1/2 ton work .
Had a freind use his 05 1/2 ton as a example of the way the fans needed to cycle and the modes I described is just the way the fans worked on his 05 1/2 ton .
Remember these are the 05 stock factory fans (34" radiator) and not the LS1 fans .
I live in Texas , so summers get hot here also .
GM
Old Apr 12, 2006 | 06:31 PM
SnakeOiler's Avatar
You can set this schematic up with the 05 fans, LS1 fans or flex-a-lite fans - you just need an '05+ computer in order to use pin 33.
Old Apr 16, 2006 | 08:49 AM
Colby 04's Avatar
Jesse mentioned something about enabling another pin when he did my tune. He said something about the A/C being wired from pin XX and the temps being wired from pin 42. I wonder if it's set up like you guys are describing. BTW, my truck is a 2004, Jesse put my tune on a BRAND NEW PCM(at my request), so I wonder if my PCM has the capability that the '05s do?
hmm....
Wrecker 426
Sep 30, 2015 09:39 PM
Silver8ado
Sep 30, 2015 11:42 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
kalikid06
Sep 20, 2015 07:46 PM
97gmc
22
Sep 8, 2015 10:56 PM
