Nelson Harnass Install...???hard???easy
Old May 24, 2007 | 07:01 PM
bgray's Avatar
TOTM: June 2007
Default Nelson Harnass Install...???hard???easy
jsut curious....
is it easy or hard...do they come with good instructions...??
just curious cause i havent seen them but there waiting for me at my shop
Old May 24, 2007 | 07:08 PM
RandomHero's Avatar
if it's anything like dlh2006's harness then it'll take you less than an hour
Old May 24, 2007 | 08:08 PM
xlcooplx's Avatar
true! pretty straight forward
Old May 24, 2007 | 09:15 PM
LS1TRUCKGUY's Avatar
installed mine in about 45 min. taking my time.
Old May 24, 2007 | 09:20 PM
JeevesRules's Avatar
easy .... hardest part is making the whole in the firewall(if installing the pcm under dask) and getting all the connectors threw it by yourself! ..... then again my truck was made for 1 wire ignition ..... my firewall grommets were probably a bit smaller then most of your guys .....
mine had a 6 wire hook up ..... i used 10 gauge for everything
1 - Ground
1 - Ignition (attached to 3 fuses)
1 - Main Batt. (1 more Fuse)
1 - Fuel Pump Power
1 - Tach Wire
1 - Speedo Wire
everything else just plugs right in ..... the o2's connector that came with my harness are the 2x2 style o2 sensor. the 02 sensors that i bought for the 01 truck were a 4 pin flat connector, i just took them back and got the 02's with a 2x2 pin connector, ls1 or vette style then parts guy told me.
easy to hard
1-2-3-4-5
Old May 25, 2007 | 10:33 AM
bgray's Avatar
TOTM: June 2007
we are referring to jsut the electric fna harnass.....good post tho!!! lol
Old May 25, 2007 | 01:19 PM
moregrip's Avatar
what a rush!
the e-fan harness isn't difficult at all
Old May 25, 2007 | 01:23 PM
BlownChevy's Avatar
blownerator
25 Year Member
you might want to replace the relays that come with the harness. I have gone back to the clutch fan, the 17 hp was not worth the headache IMHO.
Old May 25, 2007 | 01:24 PM
slowprocess's Avatar
4 years running on a Nelson harness and zero problems to date.
Old May 25, 2007 | 01:27 PM
BlownChevy's Avatar
blownerator
25 Year Member
There have been a few people that have had issues with the relays, i think if you upgrade them the harness will be fine.
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
