Nelson e-fan harness?
Old Dec 30, 2009 | 11:10 PM
  #21
Brutal_LS1's Avatar
what exactly does activating pin 42 mean? is a tune required to activated it or does this mean that you physically have to install a pin?
Old Dec 30, 2009 | 11:13 PM
  #22
GMCtrk's Avatar
You have to put a PCM pin wired to the harness into the PCM harness. It's not hard to do it. Also you do have to tune for the efans.
Old Dec 30, 2009 | 11:30 PM
  #23
Brutal_LS1's Avatar
but the Nelson or Blackbear harness comes with everything you need right? so once a person buys that and installs it, all they need is a tune right?
Old Dec 30, 2009 | 11:31 PM
  #24
GMCtrk's Avatar
yes sir.
Old Dec 30, 2009 | 11:34 PM
  #25
Brutal_LS1's Avatar
roger that.
Old Dec 30, 2009 | 11:50 PM
  #26
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by GMCtrk
yes sir.
Originally Posted by Brutal_LS1
roger that.
10-4 over and out
Old Dec 31, 2009 | 12:02 AM
  #27
GMCtrk's Avatar
before you stick the pin in the PCM harness, take a needle and stick it down in the pin hole. There is a rubber stopper in there from the factory. I didn't realize that on my first attempt, the pin meet insurmountable resistance and I snapped it right off! Luckily for me, when I bought a spare PCM from the yard it came with the end of the harness, so I have about 100 extra pins lol
Old Dec 31, 2009 | 01:13 AM
  #28
Brutal_LS1's Avatar
That's definitely good to know.
Old Jan 4, 2010 | 06:58 AM
  #29
dhpro's Avatar
Originally Posted by 03_Denali
I installed Nelson's harness in '05 on my Denali and I suffered from a melted harness and went through relays every 3 months. I believe at that time he was using the same gauge wires and relays that was used for his LS1 fan setup. Hopefully he has upgraded his wire gauge and upped the relay amperage. I switched to Justin's (Blackbear) harness and I have not had a bit of trouble. Justin's harness is only $98 shipped and is far superior IMO.
Greg
I had this same prob with the relays melting once and was concerned that the wire guage might be too light. I spoke with them and they reassured me that the prob must lie elsewhere...I changed the relays and found I had a loose connection somewhere else that was the actual cause...no probs since, but still wonder about the guage as I get voltage drop whenever the fans engage despite having gone 145amp and "Big 3" wire upgrade...
Old Mar 25, 2010 | 06:40 PM
  #30
MISTERIO's Avatar
Greg
man i having the same problem the relay in the middle that reads 87 melted down ... i I've only had the harness for like 6 months on a 05 fan set up
