need some help on what to use with the ls7
Old Oct 20, 2006 | 02:58 PM
pewter00's Avatar
Default need some help on what to use with the ls7
i just need these 2 questions answered ASAP.. PLEASE
i'm going to be droppin an ls7 in my truck.. its a 2000 silverado.. i was looking into just doin a cam, tune, stall and intake, headers and exhaust as far as the mods go.. now my questions are
i was looking at the FLT transmissions.. do i need a built 4l60e, 4l65e, or 4l80e? there is 3 different levels on each so i dont know which to go with?
i was planning on getting a moser 12 bolt rear end.. will this hole up fine? what gearing should i go with? the truck is going to have some 22x12's in the rear for shows and 20x12's in the rear for when i take it to the track..
help ASAP please.. i'm ready to get things ordered
Old Oct 20, 2006 | 04:28 PM
i'm fairly new to the performance side of GM trucks, but i know a thing or two about LS1s... with that said, i don't think the 4L60 or 65 will even be close to being strong enough for a 505 hp LS7, the 80 is the strongest of your options. maybe someone else can chime in with a stronger option.
a moser 12 bolt should hold up pretty well, thats what i've got in my TA. my guess is that with that tall of a tire (wheel) you might need a 4.10 gear or maybe a 4.33
Old Oct 20, 2006 | 05:09 PM
thunder550's Avatar
High on diesel fumes
Chuck @ FLT says that he can build a 65E to handle somewhere around the 500 rwhp range, which would be right at the borderline of what that motor will put out. Might want to consider the 4L80E. A stock 80E with a shift kit should be able to handle that LS7 just fine.
Old Oct 20, 2006 | 05:54 PM
jakebdb56's Avatar
moser 12 bolt should hold up pretty good. as for the tranny, it wouldn't be a bad idea to get a beefed up tranny while you're at it if you're going to add some serious hp down the road...
btw, can you order me an LS7 too?
Old Oct 20, 2006 | 06:00 PM
pewter00's Avatar
i'm getting a built tranny.. i figured by sayin FLT everyone would know that i was goin with a built tranny.. i was leanin towards hte FT level 5 tranny just so i can have room to play
Old Oct 20, 2006 | 06:16 PM
thunder550's Avatar
Level 5 4L65E? That won't give you much room to play IMO. Call Chuck and he can tell you for sure, but if it were me I would go with an 80E. Like I said, you don't need much work put into the 80E to make it handle that. Parish ran an 80E with just a shift kit well into the 700hp range and it was fine.
If you piece it together right you will pay about the same for a level 5 4L65E as you would for a lightly-modded 4L80E with the conversion kit.
PM me if you want a good reference for the guy who built mine and a few other member's trannies. He's a good guy and priced very well.
Old Oct 20, 2006 | 06:50 PM
pewter00's Avatar
no i meant level 5 4l80e.. is that still not enough?
Old Oct 20, 2006 | 06:53 PM
nightrunner's Avatar
Mr. Obvious
id say so the level5 80e is rated for what 1000hp+
Old Oct 20, 2006 | 07:00 PM
thunder550's Avatar
That's overkill actually....a very mildly built 80E should handle that LS7 no poblem. Actually a stock one would probably be ok, but as I said, a shift kit would be a good investment. Unless you plan on making 700+ rwhp I wouldn't worry about getting anything crazy.
Old Oct 20, 2006 | 07:03 PM
CHEVRACER83's Avatar
a stock 80E would be great but as said, with a LS7 your gonna want the crisp shifts.
so go with a shift kit.
trust me i work for GM...
Texas5.3_1251
Mar 5, 2016 08:10 PM
OHsixLS3
Nov 22, 2015 07:45 PM
thewrx
Oct 6, 2015 10:59 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
OHsixLS3
Sep 25, 2015 11:20 AM
