Need Some Help With Injectors, Flyer Parish Are You Out There
Old Oct 22, 2004 | 03:21 PM
Default Need Some Help With Injectors, Flyer Parish Are You Out There
I need some flow rates on injectors, Here is my situation
* father has an 03SS with a p1sc, cam exhaust, all the goodies, we have finally ran out of injector (pulse width is around 33) check fuel pressure is around 100 psi in boost(fmu unit)
* we are going with the 8.1 injectors #17124531 & deleting the fmu unit
* I have found out the lq9 uses a 25.2lb injector vs my 24.8lb injector
* I would like to install his on my truck
I need the IFR so I can adjust accordingly the 8.1 & the lq9, at least something to get me in the range.
If anyone has any other ideas as to possible cause chime in. the truck has normal driving characteristics until pe kicks in & you get into max boost. the ltft values are -2%, fuel pressure is 100 psi, auxillery fuel pump is functioning, plugs good, O2's drop to almost 0 during boost. When fuel drops out you can see it on the scanner.
Old Oct 22, 2004 | 03:28 PM
Flyer's Avatar
5.2 should get you close on the 42 lb'ers.
Not sure about the LQ9 injectors. Check out the flash for it.
Old Oct 22, 2004 | 05:45 PM
BigTex's Avatar
The SS uses the same injector as all the other trucks, sorry. Its the same part number and the same flow rate in LS1 edit.
$A_Money$81
Mar 27, 2023 10:25 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
shootermwc
Oct 8, 2015 01:45 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
