Need more nut on low end
Old Sep 8, 2005 | 11:46 PM
mason110's Avatar
Default Need more nut on low end
What do you guys suggest on low end performance to get more nut from dead stop? Gears and converter maybe 4.10's and a 3000 stall? Its a 4.8 2wd. TIA
Old Sep 9, 2005 | 12:02 AM
02sierraz71_5.3's Avatar
gears yes
3000 stall no
supercharger, torquer cam, full exhaust
Old Sep 9, 2005 | 01:31 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
IMO I would go with 3.73s or 4.10s and a 3000 stall. The 3000 stall really didnt kill my gas mileage until I stepped on it hard and trust me with the 3000 stall you wont be able to keep your foot out of it cause its so much fun, instant melted tires. I enjoyed my 3000 stall when I blew it I went to a 3400 stalls are so much fun and provide a nice smoke show when you are so inclined to give one just be sure to keep the local tire shop on speed dial. IMO a stall is the best bang for the buck as far as et drop but it wont add hp so on the highway races it wont help you but street light to streetlight it will haul ***. With the nitrous, stall, and cam it will lay a black mark all the way through 1st.
Old Sep 9, 2005 | 01:40 AM
Mr. Sandog's Avatar
Originally Posted by 02sierraz71_5.3
gears yes
3000 stall no
Actually, I would have recommended the opposite.
I am seriously considering going back to 3.73's and getting a converter, so I can have the tire-shredding, off-the-line power I want, with the 19-20 MPG I used to have back in the day....that went away with my 4.10's.
Can't argue with this one.
Old Sep 9, 2005 | 02:17 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
What gears do you have now? I went from 3.73 to 4.10 and a PI 3200 with a 125 wet shot(on my '01 4.8 2wd) and let me tell you, there's no way you will hook if you punch it from a dig unless you have at least some DR's. I barely hooked well when I had DR's on...even after lighting them up well. I had start without the nitrous then hit the spray at about 20 MPH for it to hook. Just an FYI
Old Sep 9, 2005 | 09:03 AM
zippy's Avatar
i would have to say a 4.10 gear and a 3k stall should fix any lack of off idle performance.
Old Sep 9, 2005 | 12:02 PM
Tractionless's Avatar
That would definitely cure your weak off the line problem.
edit: Make sure you get a posi if your truck didn't come with a locker. If not... your truck will be even slower off the line...
Old Sep 9, 2005 | 12:16 PM
Mr. Sandog's Avatar
Then you'd end up like him (look at his screen name)....
Old Sep 9, 2005 | 02:43 PM
Keith's Avatar
Low end performance - supercharger.
Getting away from a stoplight in a hurry due to the engine getting up in it's rpm range easier - 3000 stall.
Old Sep 9, 2005 | 05:16 PM
so what about us 5spd guys lol
i sure can melt em thru first and get em 1/2 thru 2nd and scratch into 3rd...all i got is intake/exhaust. next on the list is headers, no cats, and duals with a Xpipe. and a custom tune....maybe dyno tuned but i might do a mailorder i dunno. plan on running 33" All Terrains and some 4.56 gears though
