need ides???
Old Sep 27, 2010 | 01:55 AM
gmc6.0's Avatar
Default need ides???
im trying to reach 550 rwhp ive done almost everything i dropped in a 6.0 with wcch stage II 317 heads..kbracing t76 turbo kit, injectors, msd boostapump, intake pump,4.10 gears, the kit is set at 5 lbs but im only making 360 rwhp the tuner said that once he installs the meth kit i should gain another 85 hp but im looking to achieve something close to at least 550 rwhp. oh yeah my truck is a 06 cc lifted six iinches with 35 inch tires on a 17 inch rim...any suggestions?my next mod is to drop in the 80e...
Old Sep 27, 2010 | 02:09 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Bolt on stock size tires and go back to the dyno. You will be surprised at the increase. The big tires are killing your numbers.
Also, are you still using the stock cam, or have you switched to a good boost cam?
Oh, and turn up the boost already! 8 psi without meth(with a good tune) is alot more fun than 5 psi. Then add the meth and go from there.
Old Sep 27, 2010 | 02:16 AM
gmc6.0's Avatar
thats in the making with the meth itll go on in the morning but what good is it if i throw on my stockers? i wont be driving with them on? whats a good turbo cam this is my dd ride i rarly see the track
Old Sep 27, 2010 | 10:34 AM
gmc6.0's Avatar
....anyone else
Old Sep 27, 2010 | 10:42 AM
SLOXCAB's Avatar
Turn up the boost and those 35s are kiling your hp...what did ryne say was the max boost that's he will tune it 2
Old Sep 27, 2010 | 11:08 AM
gmc6.0's Avatar
yeah i know im highly thinking bout getting rid of the lift and lowering it all i want it to get close to 550 rwhp he said my trans is going out too and he has a 80 e there suppose to quote me today....5 lbs is where it is set at..
Old Sep 27, 2010 | 11:15 AM
SLOXCAB's Avatar
What about your fuel system?? Is that all stock besides the injectors. Maybe look into a bigger fuel pump set up
Old Sep 27, 2010 | 11:35 AM
gmc6.0's Avatar
yup ryne already did an intake and a boost a pump the fuel is spot on im thinnking maybe a cam? but ive seen people on here making way over 500 rwhp similar to my setup..maybe after a cam and the 80e ill be there..
Old Sep 27, 2010 | 11:47 AM
SLOXCAB's Avatar
Maybe but those 35s are killing you. Crank the boost up to over 10psi with the meth and run some 456 gears
Old Sep 27, 2010 | 01:48 PM
gmc6.0's Avatar
is it worth throwing a cam in there how much different would it make going from 4.10 to 4.56
