Need Help With Traction Quick!!!!
Old Oct 9, 2004 | 01:55 PM
snoman's Avatar
Originally Posted by sfj
you could also get a larger radius tire to make it harder to spin in answer to your original question
and decrease the advantage he gained with deeper gears, this is smart.
Old Oct 9, 2004 | 07:19 PM
I think you should consider sticky tires before the 3000 stall. If you can't hook with the stock converter, then the 3000 stall will only make things worse.
Old Oct 9, 2004 | 07:39 PM
DUNGBEETLE's Avatar
Banned
Thats what I was thinking. I think I might do both at the same time. Anyone know where to get some cheap slicks at. It would just be for the track. I am going to use my street tires besides that.
Old Oct 9, 2004 | 08:04 PM
I've never put slicks on my truck. If I ever do, it will probably choose 26x9.5-16 Mickey Thompson Sportsman pro's on some cheap factory take-off rims.
Old Oct 9, 2004 | 09:47 PM
foxspy's Avatar
Originally Posted by DUNGBEETLE
My tire pressure was about 30psi. NEED HELP?????
Cal-tracs and ET Streets are your answer.
And if you're serious about racing, look into QA1 shocks.
Vortec350ss
Jan 12, 2016 10:36 PM
Wrecker 426
Oct 7, 2015 12:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
