Need Help With Traction Quick!!!!
Old Oct 9, 2004 | 01:34 AM
DUNGBEETLE's Avatar
Banned
Default Need Help With Traction Quick!!!!
Went to the track tonight, first time since i have had my 4.10's installed, with the pcm tune. I hit it from the pit and the tires started smoking. Never happend before. What is the best way to control my traction. Planning on getting a 3000 stall converter, but there is no way with is smoking just with 4.10's. My tire pressure was about 30psi. NEED HELP?????
Old Oct 9, 2004 | 06:06 AM
snoman's Avatar
Change tire type maybe but also do not give it WOT until you are rolling a bit. You might spin the tires abit before run too. nless you go to a much sticker rear tire a 3000 rpm stall would be a waste. Also then real main reason you change the stall is when you cam the engine and changes its torque curve because most people that gain a good bit from them is because they are not geared correctly to begin with and it helps their launch some. In a properly gear car a higher stall will not help that much unless you have changed the engines torque curve to a higher RPM too.
Old Oct 9, 2004 | 11:30 AM
DUNGBEETLE's Avatar
Banned
What kind of tire would be best for the situation?
Old Oct 9, 2004 | 11:54 AM
snoman's Avatar
What are you using for rubber now?
Old Oct 9, 2004 | 11:57 AM
DUNGBEETLE's Avatar
Banned
stock street tires. I think 255/70/r16
Old Oct 9, 2004 | 12:02 PM
snoman's Avatar
Tread pattern type? (blocky or a basically solid and grooved contact area and brand) Also, how about tire pressure as well.
Old Oct 9, 2004 | 12:21 PM
sfj
i disagree about the stall to an extent ... because i know more than one person that started with gears and a stall and the stall (one of wich was a 410 and the other 373) and the 3k stall was still very beneficial as far as take off i agree make sure to take off slow ... i guess the best way to describe it is to roll into it and not deck it right out also practice makes perfect the more i run mine the better i get at it and the lower the e.t's and you could also get a larger radius tire to make it harder to spin in answer to your original question
sfj
p.s. i run about 25 psi at the track on stock radials and that helped me out a lot
Old Oct 9, 2004 | 12:39 PM
Tire pressure will help,but if your racing you need drag radials. I use BF Goodrich Comp TA. They work well,but they would last about 2,000 mi on the street.
Old Oct 9, 2004 | 01:54 PM
DUNGBEETLE's Avatar
Banned
im planning on going with the streetfighter. What does the engine characteristics mean? do you have to have the same characteristics or is that like a guide?
Street/Strip Performance Torque Converter General Application Chart
Torque Converter Series advertised
camshaft duration rear gear ratio engine characteristics expected rpm stall speeds
small block big block
Sizzler® stock to 260° stock to 3.23 smooth idle, stock comp. ratio 1500 to 1700
1700 to 1900
Saturday Night Special® stock to 265°
stock to 3.23
smooth idle, stock comp. ratio 1600 to 1800
1800 to 2000
Breakaway® 265° to 280°
3.00 to 3.73
fair idle, mild modifications 2200 to 2400
2400 to 2600
StreetFighter® 280° to 300°
3.55 to 4.56
rough idle, large fuel system, raised comp. ratio 3000 to 3400
3400 to 3600
Super StreetFighter™ 280° to 310°
3.73 to 4.88
rough idle, large fuel system, raised comp. ratio top end power 3500 to 3800
3800 to 4000
