Need help with some 3.905 mahle
Is this a set of 3.905 pistion or 3.910 pistions? I had a 5.3 block bored to a 3.905.. These pistion seem very tight in the bore.
Are these pistion for 3.910 bore..
Pistons are 3.905,the rings are 5 thousands overthe piston size so you can file fit them , are you doing that part yourself? when you had it honed did the machine shop have a piston to base off of, i only ask because different manafactures have different tolerances wondering if they based the hone off of your word of 3.905 or measured the piston . depending if your spraying it or fi or na is how should figure out your ring gap guidelines should have came with the rings
The shop bored the 5.3 block with out the piston. I guess summitracing sent me the wrong pistons
Haha, No other reason then I wanted a 3.905 bore
Summit show they are for 3.905 bore
Mahle LS1314905F04 - Mahle PowerPak Piston and Ring Kits - Overview - SummitRacing.com
