Need help solving pinging issue
Old May 27, 2005 | 03:24 PM
FastEddie's Avatar
Default Need help solving pinging issue
New to board and have a question in regards to pinging with a 2000 4.8l sierra.I have tried 89 and 93 octane with no success and took timing out with a predator but it still pings under load. Is there something else that would cause this besides timing? I have an airaid cold air and mit along with a throttle body spacer,exhaust and a throttle body hot water bypass on the truck. Any of your help or wisdom would be very appreciated. Please give me some ideas on what to do. Thanks
Old May 27, 2005 | 03:30 PM
budhayes3's Avatar
PT's Slowest Truck
Could be running a little lean, or possibly carbon deposits. If you have a scan tool you can check out your long term fuel trims, if it's postive, it's lean. If that's OK, you could try doing a top end clean with Seafoam (not a bad idea to do as a maintenance item anyway)
Old May 27, 2005 | 08:54 PM
BADDAK's Avatar
Where can you get Seafoam from?
Old May 27, 2005 | 09:20 PM
Try fuel filter first,lean conditions WILL cause detonation
Old May 27, 2005 | 09:34 PM
dewmanshu's Avatar
Moderately Differentiated
Pinging as in audibal pinging? Or something you are interpretting as pinging on a scanner? 2000's are known for KR...but audible pinging is bad none the less. It defintely means too lean or too much timing. Any codes?
Old May 27, 2005 | 10:39 PM
KySilverado's Avatar
Sticking EGR valve if equipped comes to mind.
Old May 27, 2005 | 11:28 PM
02sierraz71_5.3's Avatar
vacumme leaks can cause spuradic problems Im finding out about that now
Old May 28, 2005 | 12:23 AM
budhayes3's Avatar
PT's Slowest Truck
I get it from NAPA.
Idryfly5
Sep 2, 2022 08:55 PM
lucas287
31
Jan 12, 2021 06:18 AM
Tydriver
45
Oct 23, 2015 09:19 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
