Need help removing fan from old water pump.
Old Jul 14, 2010 | 03:27 PM
SUPERCHARGE's Avatar
Default Need help removing fan from old water pump.
Hey guys, I replaced my old water pump some time ago but was never able to take the fan off the old pump. In the next week I'll be hitching a porsche 911 at the race track and the weather out here has been really hot. I don't want to chance it and want to put the clutch fan back on.
Those who have done that know that there is no way to properly grab the pulley tightly enough to remove the fan. The hayne's manual method was a complete joke. I tried putting a coat hanger through the holes in the pulley but snapped after so much torque.
Any suggestions? Thanks!
Old Jul 14, 2010 | 03:29 PM
fredkj3's Avatar
... i had to heat the nut up with a torch(not alot).... and use a strap wrench to hold the pulley....
Old Jul 14, 2010 | 03:52 PM
Yeah, Haynes manual way of doing it...didn't have a torch, but tried that method with heavy grit sandpaper surrounding the pulley. At any rate, the pumps off now, so the strap idea won't work at this point. I'm really hoping there are other ideas.
Old Jul 14, 2010 | 04:37 PM
blowngmc's Avatar
I have the tool snap on sells and works great. Before I had that one time I pulled off the back cover off the waterpump and lodged a prybar inside the fins and that worked, I have also seen people use a hammer and chissel to break it free.
Old Jul 14, 2010 | 07:04 PM
wentbig's Avatar
Pipe wrench jaws almost closed where the belt would ride. Shock the wrench that is turning the nut with a dead blow hammer or a single jack 4# hammer.
Old Jul 14, 2010 | 07:05 PM
Mrgoodwrench3's Avatar
There is a tool that holds 2 of the bolts for the pulley, then a large wrench is used to turn the clutch off.
http://buy1.snapon.com/catalog/item....store&tool=all
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Jul 14, 2010 | 07:06 PM
bbc4542001's Avatar
you need to put the pump in a vise tight and put a strap wrench on the pully i used a 15in adj and a hammer,remember counter clock wise to take it off
Old Jul 15, 2010 | 05:06 PM
sintered's Avatar
You can buy the tool, or make a simple version of your own.
I took a piece of angle iron, sawed off one of the webs so i had a flat bar. Then i drilled a hole the size of the shaft of the bolts that hold the pulley on. after a quick measurement i grinded a half-moon shape into the side of the bar so it'd clear the fan hub and contact one of the other bolts.
I removed one of the bolts and bolted the bar onto the pulley. Make sure you put it on the right way for whether you want to tighten or loosen the fan. Then put a big crescent wrench on there, use the bar as a counter-acting support and loosen it up. Reverse the procedure to install the fan.
i've used that little bar 3 times so far.
Also, i think either advance auto or autozone (or both) have a loan-a-tool program where you can borrow one of their's for an afternoon for free. i've heard they are a PITA to use so i just made the bar to do it.
Old Jul 15, 2010 | 09:08 PM
fredkj3's Avatar
a pipe wrench on the pulley works too... but the torch is whats going to free it up.... go buy a cheap map or propane torch.....
Old Jul 15, 2010 | 09:21 PM
fastrt's Avatar
11 Second Truck Club
I say pipe wrench too. and even a walmart propane torch would work. or a large vise and a wrench that fits the fan clutch.
